Home > A-Series EFI / Injection > Another Cam Sensor
I've just had delivery of the new cam sensor from DigiKey.
This is a hall sensor made by Hamlin:
http://www.hamlin.com/specsheets/55075%20IssueAF.pdf
This is going in the fuel pump hole in the block and will use the fuel pump lobe as the "tooth". Hopefully it will work.
EDIT: Decided to try it on the cam wheel first.
Obviously if you are using the fuel pump hole for your turbo oil drain, then this is not an option. OK for remote mounted turbo and NA applications though.
I can remember that when I built my first cam sensor, some very helpful people on here showed me how to make a circuit with an LED to test it. I can't find the thread however.
So how would I go about making a circuit to test the switching points?
Edited by Paul S on 7th Feb, 2010.
Wire it up exactly the same as your circuit for your exixting Hall switch on the Megasquirt except put an LED where U3 would be.....
U3 is an LED anyway, you just can't see the light !!!
Make sure the LED polarity is the right way around.
This hall switch is rated at 20mA so I would probably use a 680ohm resistor rather than 470 (assuming you are going to run it at 12V).
sturgeo
Member #: 1778
Northants
Another led on the side of the case might be good for this then, that way if we have any problems we can rule it out straight away.
:cool:
You can't do that easily unfortunately....
LEDs (like any diode) don't current share in parallel. If you put two in parallel only the one with the lowest forward volatge drop will actually pass current and illuminate, the one with the higher internal resistance will simply not pass any current so won't light.
Thanks Rod, I did a search on U3 and the original thread came up.
http://www.turbominis.co.uk/forums/index.p...tid=201921&fr=0
I was actually looking for a circuit to test it without the MS. Just a manual check of the LED going on and off against a degree wheel.
If I take 12v through a 680k resistor to an LED connected to the sensor output, would this work?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Put them in series then.
http://www.twin-turbo.co.uk
Yes, I meant the same circuit as you've used on the MS but just fabricate it outside the MS, ie just a resistor and LED in series (the LED just being instead of U3).
EDIT - I've just read the rather old thread you linked...... where I said I think a cam sensor might become usefull in the future *happy*
Edited by Rod S on 27th Jan, 2010.
Yes very phrophetic of you *happy*
It looks like I must have decided on using the cam sensor sometime between Feb08 when you started the thread and Jun08 when I resurrected it.
It occurred to me this afternoon, that this particular style of sensor could be used on the cam wheel.
Just a 12mm hole though the timing plate, a screw fitted in the cam wheel to provide a "tooth", plenty of sealant and jobs a goodun.
Added advantage that it would be easier to set at the optimum point.
No reason why not so long as your "screw" tooth is a reasonably different "height" to the rest of the wheel.
Only issue might be finding a plain enough part of the wheel for the remaining 355 degrees of the sensor path - standard wheels have holes in them, verniers have bolts etc, all of which could produce noise if they were passing anywhere near the Hall switches path - you ideally need a totally clean path beneath (and near to) your switch so it only sees your "tooth" and nothing else.
My wheel has holes at the radius that I plan to fit the screw. So if the sensor is too close to the wheel then it will see the holes as well.
I may need to space the screw away from the wheel with some washers and fit the sensor at minimum depth so that I get a clean signal.
I'll also need to put another screw, diametrically opposite, but on the front of the wheel, to maintain balance.
I'll do some testing.
I'm making up this circuit to test this sensor.
So flat side of the LED towards the sensor?
Try this
http://www.tonystrains.com/technews/img/in...tall-led-01.gif
That makes sense. Like a non-return valve and the flat end is the outlet *happy*
Well, the circuit works.
The LED lights when it gets within 1.5mm of anything ferric, then stays on until you move it about 10mm away.
Tomorrow I'm going to set the cam wheel up in the lathe chuck and the sensor on the toolpost and see if it will work with a screw in the cam wheel.
that'll work a treat Paul,
I'm running a hall sensor on my trigger wheel, straight into the opto isolator on the MS.
The 10mm away (release distance) may be your problem.
Your NRV analogy is good for a hydrodynamicist (sp?) but the one I was taught was that in our water treatment plants the cation beds are cats.... and a happy cat is a positive cat ......
Unfortunately a cation resin exchange bed is the opposite polarity to a cathode, hence why I keep that little picture to remind me. :)
Now it's me getting obsessive about the cam sensor timing.
Borrowing Rod's picture:
The cam sensor signal ideally should be 150 degrees before No.1 cylinder at TDC before the firing/expansion stroke.
Hence my question elsewhere about the stroke at TDC.
So if I set the cam at TDC setup position, I then need to rotate the engine through 360 degrees, then back 150 degrees to set the sensor screw location.
Is that right?
From the way I understood Jean's answer when I asked this, the cam sensor should be a reasonable distance before the missing tooth which itself is 90 degrees BTDC on the firing stroke of No 1.
Hence my plot above.
I treated the cam timing completely by itself, ie, set the cam timing up with the marked wheel on the crank and DTI on the pushrod and then did the phase sensor independantly just counting the teeth on the 36:1 wheel and making sure it was No1 firing that I was counting the teeth before.
Just the job:
Watch it in action:
http://www.youtube.com/user/PaulSturbo#p/a/u/0/86LAN0zhXyc
The youtube video seems to have lost some of the resolution and it's not flashing anything like it really does.
Seems fine, the only thing I would suggest is on the final version, get rid of that washer or somehow make it the same diameter as the bolt head. Otherwise the sensor has two square edges it could pick up from and with the 10mm switch off distance you've already measured you won't know which is switching just from an LED and it might be so close to the cutoff point that it could be either at random.
If that makes sense.....
The washer is only temporary for the purpose of the test, as the holes are bigger than the screw head.
Once I know exactly where to fit the screw I will drill and tap it M6 and locktight a short length of the screw in. I'll also do the same diametrically opposite, but with the bolt head on the opposite side to balance it up.
That cam wheel does not have the "dots" to line it up, so I will need to get the crank and cam in the block and set it all up with the DTI and degree wheel before I can identify where to fix the screw.
I think this solution is better than trying to pick up a signal off the fuel pump lobe. It can also be used if you are using the fuel pump hole for oil drain.
I agree, the pump cam lobe was never going to have a clean square edge compared to this and I guess most people use the pump hole for the oil drain anyway.
Personally I'll stick with the dizzy drive for the moment as my optoswitch takes up so little room in that position but might try this method on the next one :)
Is that Ion Exchange?
