Home > Help Needed / General Tech Chat > Raising the top arm pickup points
evolotion
Member #: 83
Glasgow, Scotland
Ok, posting here rather than my usual haunt as im sure atleast some of you gents have experience with this on very very low cars (i recall a light blue hillclimber many years ago with this modification though the name of the owner escapes me :( )
basically in order to try to reduce / eliminate torque steer as part of a whole barrage of improvements this winter i am aiming to reduce the scrub radius. but i aim to do this while keeping my awesome deep dish 7*13's.. so have came up with a weird concoction of suspension components:
mini top arms, early a-series metro ball joints, mgf front uprights, mgf(not TF) lower ball joints, home made lower arms. Am not the first person to do this however there is a problem that i have never seen anyone address. the mgf hub is taller than the mini and a-series metro hub. so to maintain the same ride height the car must be lowered. if that makes sence. two problems arise, first teh top arm starts to sit at a daft angle where the bump stop ought to be, and secondly suspension travel becomes less linear and there is less travel to full bump.
i wish to raise the upper arm and its pickup points, without disturbing any other subframe/engine/ suspension pickup points. has anyone done this? if so any pictures? was thinking of simply cutting a half inch or 3/4 inch out the tower, shortening the hi-lo appropriately and welding in new material beneath, after cuttign below the top arm mounts obviously. should put hte top arm at a sensible angle..
Denis O'Brien.
i can't see there being any insurmountable problems, ,
you need to move both holes up exactly the same in both planes ,
then you will need to reset/ remedy any bump steer you have just built into the new setup but moving the top arm up.
opps just re read your looking to lift the whole frame, this meens the bott arms will come up too.
carl
evolotion
Member #: 83
Glasgow, Scotland
nah just looking to moove the top arm! the bottom arm position is as high as itll go without fouling the gearbox/sump/driveshafts. and mooving the whole frame will leave me with issues elsewhere. only wish to relocate the top arm mount. bump steer i will worry about after the fact,hopefully wont be drastically out and an easy solution found. my lower arm is 1/2" lower and almost 1" firther to the outside than a line drawn through the centre of the origional lower arm/tie bar mount. it is still longer than the top arm though so get camber gain on bump, albeit slightly less, which ought to be better with my low profile tyres anyways lol
Denis O'Brien.
i wouldn't go to the trouble of sectiononig the towers, i would as previously mentioned accuratly mark up the towers and redrill .
carl
evolotion
Member #: 83
Glasgow, Scotland
certainly makes sence for the rear most hole, the front hole however will be a touch more tricky, but your totally right, got to be teh best way, certainly the least fuss in terms of accurately mooving the hole centres.
Denis O'Brien.
could you induce some torque related downward force on the wheels by creating a top arm than is high at one bolt hole than the other ?
johnK
Member #: 690
Norfolk
ooh interesting subject Robert has touched upon and I need one of you keen drag racers to jump in and try it - I don't have the time!
my old friend John Miles, ex Lotus F1 - look him up for his suspension design credentials!advised me years ago to look at re jigging the mini front suspension to promote positive hub movement - ie it moves forward from the car on take off rather than the normal "regression". Apparantly he had a dabble with this on the BTCC Honda cars a while back with very good results.
In theory it sounds very simple but may not prove that way. Essentially the front tie rod pick up point needs to drop in relation to the pivot point in the subframe - ie closer to the ground by 25mm or so. The supension kinemtaics upon torque application will force the hub to move forwards under hard accel as the nose rises, changing the contact patch position.
If someone is going to do it I'd make it adjustable so you can go back to stock position if it gets scary.lol!
JK
If Carling made Mini engines
JK
The Miglia's have been doing this with sucsess for a few years
evolotion
Member #: 83
Glasgow, Scotland
JK
i looked into anti dive/lift suspension geometries when i was toying with all of this (assuming im not mis-reading you and thats what your suggesting), but in my head i couldnt reach a satisfactory solution.
for example, if one included anti lift (under acceleration) geometry, in order to keep the car on an even keel it would have to pull up on the driven wheel, (every force equal opposite etcetc) loosing traciton.
if you made pro lift (under acceleration) your initial movement would push the tyre right into the tarmac, then eventually the suspension will max out its droop and pull up on the wheel, result would be deadly wheel hop.
thinking about it a bit more i see what you meen about twisting the hub and altering the contact patch, different thing alltogether, but would still introduce and anti lift/dive effect and i dont have the r&d budget or time to experiemnt :( suppose i ought to put more thought into it!
im positive paul wiginton hinted towards having built anti lift (under acceleration) suspension into his new frame??
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
EDIT found pics of pauls frame and clearly visible.. jimster any pics of the miglia setup atall? really appreciate the input/knowlege.
Denis O'Brien.
johnK
Member #: 690
Norfolk
yes as I alluded to its not a simple task, and a different problem to solve on the mini suspension compared to strut arrangements
nice to see something different - if you can accurately measure the hard points it shouldbe possible to run a kinematics model to look at what the wheel is doing
JK
graemec
Member #: 1424
Carnforth, Lancs
An ugly and agricultural solution, but could you not make a stepped top arm? Weld one on top of another (obviously hacking off the irrelevant bits from each), if nothing else but to prove your thoughts work.
Then get Carl to make you some nice Ti ones!
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have thought about moving the top arm up many times, it looks simple, but it is not as simple as redrilling the hole. One side of the subframe has a big hile to get the shaft through, this makes fabrication a bit of a pain.
The idea of getting the top arm back to the position (angle) it was designed for must be a benift though.
http://www.twin-turbo.co.uk
I did build anti lift into my new front subframe. There are two videos of my car on You Tube before and after (before was my fastest 13.4 at Pod and other was my fastest 13.2 at Avon). You can clearly see the diference in the launch and upto half track. Its very easy to do, it envolves lowering the front mount of the bottom wishbone and fabricating a top wishbone with a lower front mount than rearmost mount. It took the best part of 5 years on and off to design it though. I do believe its the anti lift that helped it go quicker - and it would have been quicker still if the clutch pedal hadnt stuck down on the launch and if I hadnt missed 3rd gear.
Paul
got any links to youtube?
13.4 at Pod before http://s169.photobucket.com/albums/u210/sp...nt=MVI_0511.flv
13.2 at Avon after http://www.youtube.com/watch?v=_5-yGxNwXsM
You can hear the difference and see the lift in the first video and see that the car is perfectly flat in the second. Its very evident after the first gearchange
Paul
Edited by paul wiginton on 28th Jan, 2010.
JetBLICK
Member #: 1261
Droitwich
Did you do this in the end? Did it work as expected? I'm looking at doing it to fix some of the geometry issues from running the car low, together with a balljoint spacer on the bottom.
evolotion
Member #: 83
Glasgow, Scotland
I did, raised the arm about 25mm iirc. Drove real nice but literally finished the frame, drove to shakespere county ran a 12.4 cracked a liner and the mini hasnt turned a wheel since, due to me deciding to start my own wee buisness. Didnt get time to see how effective it was and changed far to much about the suspension to say any one thing helped sorry..
Denis O'Brien.
D4VE
Member #: 10749
lowestoft suffolk
I believe nick has done this to his clubby?
Nothing gets past Dave lol
JetBLICK
Member #: 1261
Droitwich
Yer he has, cheers, just checked out his instagram. Looks loads better.
Just been doing some reading on anti lift, sounds interesting,but nothing i'm keen to get that into. However, if anyone knows, I'd be interested to know what you think the effect of raising the bottom arm mount would be, without moving the tie rod mount? It was an idea i had in order to save using a ball joint spacer, but i decided against it as i didn't want to mess around with the angles of things i don't really know much about. The result would be an axis in side view between the lower arm and tie rod mount that is closer to being parallel with the top arm. What would be the benifits and drawbacks of such a set up?
Dan
Edited by JetBLICK on 24th Sep, 2016.
