| Home > General Chat > my first GT20 RR power run | |||||||
30th Jan, 2010 at 02:41:28pm
Popped over to the rollers this morning with kean (T2clubby) to give mine a run up and see what this new GT20 is doing and to see if we could find his missing 50hp from the northampton rolling road day.
30th Jan, 2010 at 03:34:45pm
and i thought my car was laggy! turbo 16v k-series 11.9@118.9 :)
30th Jan, 2010 at 04:21:13pm
Big power mate, but as Denis says looks like a fair amount of lag with the GT20.. hows it behave on the road? |
30th Jan, 2010 at 04:23:45pm
lovely on the road, i can't fault it tbh. doesn't feel anywhere as laggy as my old T3 did.
30th Jan, 2010 at 04:29:24pm
will have to pop over and go for a drive :) |
30th Jan, 2010 at 04:30:52pm
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
30th Jan, 2010 at 04:35:15pm
Good numbers there NIck, but as said seems to be quite high up the range. How far dare you take it?? On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
30th Jan, 2010 at 04:37:07pm
limiters at 6800 so think it kicks in 200 earlier on the jolt doesn't it? not going to touch the limiter for now, i'll see how it goes on the 1/4 first. Edited by Nick on 30th Jan, 2010. On 20th Oct, 2015 Tom Fenton said:
30th Jan, 2010 at 04:41:13pm
If only there was a way to run that compressor without the lag On 28th Aug, 2011 Kean said:
30th Jan, 2010 at 04:43:04pm
Looks good. Which cam do you have in there? On 7th Oct, 2010 5haneJ said:
30th Jan, 2010 at 04:45:45pm
Good results Nick.
30th Jan, 2010 at 05:00:33pm
On 30th Jan, 2010 minimole23 said:
Looks good. Which cam do you have in there? avonbar phase 2. On 30th Jan, 2010 Paul S said:
Good results Nick. To get nearly 200hp from 20 psi is top notch. Just odd that the torque curve is so peaky. Does the boost build gradually and only get to 20 psi right at the top end? the boost starts to build gradually then comes in pretty quickly once its going. on the rollers it was showing 15psi off the actuator so i was sat in the car opening the bleed valve to get the boost up. i'm guessing it was at 20psi for the last 1000rpm or so, was too busy looking at the boost/afr to watch the revs. weird thing is it shows 17psi off the actuator on the road and a fair bit leaner on the afr too. whereas it was fine on the rollers. On 20th Oct, 2015 Tom Fenton said:
30th Jan, 2010 at 05:33:16pm
Nice one. Would be good to see the boost profile to compare it to the GT17 ones we got from the RR day. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
30th Jan, 2010 at 05:57:46pm
that thing made me jump when it spat flames at me while i was holding the exhaust probe in Edited by MONSTER HEDGEHOG on 30th Jan, 2010.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
30th Jan, 2010 at 06:05:14pm
well done nick ,what cc and cr are you on? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Jan, 2010 at 06:08:06pm
30th Jan, 2010 at 06:11:47pm
On 30th Jan, 2010 robert said:
well done nick ,what cc and cr are you on? i'm on 1293cc and 8.7:1 sorry about the tyre incident hedgehog, should have undone me harness before i started reversing, lol. On 20th Oct, 2015 Tom Fenton said:
30th Jan, 2010 at 06:25:34pm
lol , im not bothered about it nick, i was almost as worried about your car as i was mine. colls is always a pig to reverse up to for some reason.
30th Jan, 2010 at 07:28:54pm
Well my curves are nowhere as smooth as Nicks (oo err missus!) but I finally got the numbers it should have made at the rolling road shoot out last year.
857 Posts Member #: 1778 Post Whore Northants |
30th Jan, 2010 at 07:33:05pm
Both look good, t2clubby have you changed anything since the NM RR day? |
30th Jan, 2010 at 07:53:52pm
Not really, just the way the boost came in on the run, at the shootout they tried 20psi from very low down and it surged its ass off. This time I started on low and switched it manually, I used to let the ecu do the same.
30th Jan, 2010 at 07:56:22pm
these want correcting to 1001 mb(pressure at rr on sat morning ) to compare with other DIN spec graphs i think ?
Edited by robert on 30th Jan, 2010. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Jan, 2010 at 08:12:29pm
TOP one chaps, pleased for you.
31st Jan, 2010 at 12:03:54am
On 30th Jan, 2010 mini13 said:
If only there was a way to run that compressor without the lag ![]() what on earth are you getting at here Joe??? Lol! Stop messing around and get yours on the rollers so we can all see. In the 13's at last!.. Just |
31st Jan, 2010 at 08:17:14am
correct away robert if you want :)
