| Home > Help Needed / General Tech Chat > confusing running issues ...SOLVED | |||||||
![]() 216 Posts Member #: 5647 Senior Member swindon wiltshire |
31st Jan, 2010 at 12:09:52am
im hoping im going to be able to get some advice as ive reached the end of my ideas.
Edited by Bman on 18th Feb, 2010. |
31st Jan, 2010 at 08:50:24am
Have you set the fuel pressure at tickover? it should br 3psi. If you don't have a pressure gauge there is a way to set it without.
31st Jan, 2010 at 10:50:05am
thanks for the reply...i set my fuel pressure to 4psi ..possibley some bad research on my part, and it seemed to run fine previosuly but obviously it could be that it wasnt running correctly before..so will drop it back down to 3psi.
31st Jan, 2010 at 11:01:45am
its ok ive got off my ass and found so helpful posts on here regarding the modules so that bits ok.. ill post my updates as i work through them, any more suggestions would be greatly appreciated as its so far its throwing its toys out its pram |
31st Jan, 2010 at 11:17:29am
TBH I'd also check the very basic engine condition first, ie do a compression test (or better still a leakdown if you have access to the equipment).
31st Jan, 2010 at 12:57:59pm
is it worth me rullng out compression and valves due to the car being in great working order before hving the turbo off etc ?? its been sat for about 2mths without starting so im going to check some of the basic stuff like youve suggested and go from there...ive just noticed since turning the fuel pressure doen the car is revving higher now so it seems ot have atleast dropped the fuelling down to a sensible level..its now carrying on running breifly after ive turned the engine off so would this just be the mixture being abit off now ? |
31st Jan, 2010 at 03:30:47pm
If you have a compression tester it is definitely worth doing the test, at least then you can rule it in/out.
31st Jan, 2010 at 09:05:42pm
thanks for all the info boys, its giving me plenty to check..its progressivley gettign beter and better...i guess once istopped treating it as one big problem and started working through each little bit ive found various issues.
1st Feb, 2010 at 04:45:25pm
another update after yet another day working on the mini..sorted the inlet gasket and replaced the ht leads and spark plugs which has instantly improved the whole car..starts better runs smooth pulls much cleaner etc im now down to one last running issue.
1st Feb, 2010 at 06:06:09pm
search for t pipe trick . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Feb, 2010 at 06:10:02pm
can you run the car with the fuel pressure gauge in line?
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
1st Feb, 2010 at 06:40:21pm
do what tom fenton suggests, compression test it,
6th Feb, 2010 at 11:47:06am
your adice has been invaluable so far boys, and wanted to give a quick update... replaced the dash pot oil with something abit thicker and thats definitley helped and it feels less sluggish , and def pulls cleaner
18th Feb, 2010 at 08:39:26pm
well boys im feeling like abit of a plank... after all the running issues and me constantly thinking it was going to be something big and ignoring my first hunch (timing) . i booked it in with the local mini specialists to get the timing checked and a test done on the coil etc...he rang me to say the timing was MILES out..i have no idea how that happend as it was pretty spot on previosuly and i havent so much as touched it since working on the car this time round
18th Feb, 2010 at 08:40:12pm
nobb
18th Feb, 2010 at 08:57:27pm
Nob
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
18th Feb, 2010 at 09:07:39pm
3rd nob.
the pissed up clown stood back up, did a twirl and left bollock naked, |
18th Feb, 2010 at 09:08:50pm
its been a long stressful lesson hahah
