Home > Help Needed / General Tech Chat > No lights
mate has rang who has a mini30 1989, the sidelights rear lights and dash lights are not working
i am assuming its a fuse but what and where is it on a 89? my manuals are in storage at the moment and i might pop over after work and have a look
4 fuse box on the bulkhead, from memory I think its the lowest one of the 4, but there are only 4 to choose from so I'm sure you'll find it.
Kean
Member #: 341
aka T2clubby
South Staffs
Worth checking light switch also if fuses are ok mate. The switches are shite.
+1
where the loom splits left and right at the front there are dodgy push in connectors, mine used to short blowing the fuses when these got wet
EDIT: hang on im thinking of headlights, different fuse i think
Edited by Brett on 1st Feb, 2010.
It may be worth changing the swich. I can't remember If I had back lights or not but the fronts certainly wern't working so changed the switch and everything was fine.
mcalvert39
Member #: 442
Manchester
Ive had loads of problems with my lights.
I tracked it down to poor connections on the bulkhead fusebox. Ive also put a set of relays in now to stop the switch burning out.
after metering it all it turned out to be a broken wire in the loom, semi removed from car and soldered a new piece in took less time that trying to work it out from wanky haynes manual
