Home > Wanted > Cheap Plenum and Carb wanted for my next project!!
998Turbo
Member #: 63
Hey all, well i've started on the next project (Shhh its a secret...)
But i need Another Plenum and carb... anyone want to sell me one ? Re-Builder condition is ok, i can live with it..... cheaper the better....
The Plenum is getting modified anyway,,,,,,,,,,
Email me ?
J
just don't bid on the one on ebay at the mo...
It ain't what it says....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...&category=43120
jpboost
Member #: 29
Croydon
Well spotted Dave,
Too many projects!
billydude
Member #: 48
Leicester
it's a non turbo carb
note the ring around the top of the dashpot for the clip thing is not there
and the breather pipe connection that should be sealed *wink*
Edited by billydude on 30th Oct, 2003.
It could technically be used, as the external balance pipe can be blocked off, the seals on choke and throttle spindles reversed, and the correct needle fitted, but it would leak oil / fuel from the dashpot / carb body seal (not fitted to nat-asp carbs).
I'd still not bother however - good turbo carbs are still available for well under ?30 if you look around!
Good job you lot spotted this, i was going to bid on this as i also need a carb. Got a plenum and bits but no carb.
2nd in the que please *happy*
I did bid!! good think I got out bid!
