Home > General Chat > megajolt map sensor/ max boost
Ive finaly managed (with help from the search button off here and a good friend) to get my megajolt working.
Anyhow ,through all my searching ive found out that the map sensor in the mj will only go up to 21psi, so not to sound daft but is that the max boost i can run??
From all the reading with my silly low compression 7.5:1 i gather i can run more boost than that. Or will 20is psi be ok
Whats other peoples thaughts and findings
Rick
you can run more boost but you will have to set the 21psi settings in the jolt to an advance to suit.
it just means you may not be running as much advance as you could at 21psi.
You can keep going past this, its just that it wont sense it, so you will be stuck at that retardation
I did find a higher map sensor that can be fitted, you will just have to recalibrate this to suit
Chears gents, that makes sence.
Rick
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
or change the map sensor :)
AlexF
Coupe
Member #: 2178
Leyland, Lancs
Nice to know its not possible to become more retarded than that then!
I made that word up, im glad it was understood
you're an insaniac
Tell me about it, im so dangerous people walk out of the room when I walk in it...
....im sure thats why anyway
have you tried washing you smelly bastard?
t3gav
Member #: 229
Gavin@minispares.com
kent
Apparently you can use an external map sensor as if it was a tps too... http://www.autosportlabs.org/viewtopic.php?t=2067
