| Home > Help Needed / General Tech Chat > Carb float level | |||||||
12th Jan, 2005 at 07:09:44pm
Can anyone help me with the procedure of doing the float level?? -MINI CLUBMAN 1380 TURBO- |
13th Jan, 2005 at 07:55:10am
Ill see if ive still got some instructions.
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
15th Jan, 2005 at 10:02:34am
turn the carb upside down , the float is now resting on the seat under its own weight, hold a ruler across the bottom face running throgh the center of the float where it is 'hollowed' -or front to back axis- , this is the level ,bend the brass tang to correct the hieght |
15th Jan, 2005 at 03:10:18pm
Excellent stuff, cheers Stu:)
17th Jan, 2005 at 11:01:23pm
just touching |
17th Jan, 2005 at 11:49:46pm
Many thanks:) -MINI CLUBMAN 1380 TURBO- |
18th Jan, 2005 at 11:00:58pm
I thought it was ment to have a gap of 0.5mm? |
17th Apr, 2006 at 11:19:36am
What should the measurment be when using this metod? It didn't say in my maual. On 13th Jul, 2012 Ben H said:
17th Apr, 2006 at 02:00:39pm
I had the centre of the float just kissing the rule. -MINI CLUBMAN 1380 TURBO- |
17th Apr, 2006 at 05:14:36pm
I am certain Haynes manual states 0.5mm, but i seem to have missplaced my metro one so I cant check..... |
17th Apr, 2006 at 05:20:21pm
Let's be honest guys - 0.5mm or touching - if it's either one of them, you're unlikely to have problems. If you do - it's unlikely to be the float level! On 17th Nov, 2014 Tom Fenton said:
17th Apr, 2006 at 08:29:40pm
you should no tone you have still got my turbo manual you git.lol always looking for them bigger bunches of bannanas |
