Home > Help Needed / General Tech Chat > metro turbo
nath
Member #: 8122
wrexham
can get cheep metro turbo 1.3 butt chains have snapped
can anyone tell me what would need replacing and how much maybe??
thnks 4 help
stefaz
Member #: 1656
stoke-on-trent
timing chain??
nath
Member #: 8122
wrexham
yeh it snapped
Yep so i needs replacing. put a duplex on
Rick
nath
Member #: 8122
wrexham
thanks ..
is that all it will bee??? nothing else broke?
nath
Member #: 8122
wrexham
anoyonee knoww ???
Anton
Member #: 764
Staffordshire
Duplex chain is about 25 quid.. but I would expect the rest of the engine to be pretty unloved if the timing chain is bust.
Andrew 998 mini
Member #: 5639
Weert Holland
id pull the head of and have a quick look for damage if your lucky damage could be minimum
but as said sounds to be an unloved engine.
Cheers, Andrew
Little car Little power........... For now That is!!!!!
1983 mini down paid, must collect soon and get welding!
Dependes on how fast the engine was going when it broke to how likely there is damage.
The only things I think that could have happened are:
Con-rods could have hit the cam lobes;
valves could have hit pistons.
nath
Member #: 8122
wrexham
thnks 4 all the help.. butt after all that found out chains snapped then it was fixed and run for 18 months after but the man took chains and sprocket off so it needs duplex chain + sprocket and some othere little stuff and got it for £50 *happy**happy**happy**happy* cant complain
Has anyone ever seen a snapped A series chain?
I was just about to reply yes, but it was the tensioner.
Rick
I saw one years ago on a friends 998 road car.
He was pretty lucky, as I seem to remember he fitted a new chain and it hadn't bent any valves.
IIRC,
the valves will miss on most standard cams, however I'm sure the lobes will hit the rods on all 1275's (unless you are incredibly lucky!
