| Home > Technical Chat > Crank dampers | |||||||
10th Feb, 2010 at 11:03:31pm
I have been thinking about this today.
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
10th Feb, 2010 at 11:06:50pm
Put a new one on it. If you're not sure then replace it is my rule.
157 Posts Member #: 6496 Advanced Member Somerset |
11th Feb, 2010 at 05:06:31pm
I rang MED the other day for some advice on exactly the same question...the dude on the blower (steve?) told me that provided the rubber is in excellent condition, they should all do the job (even standard, apparently!) for a street motor. On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
11th Feb, 2010 at 06:14:08pm
That last comment makes me laugh On 26th Oct, 2004 TurboDave16v said:
11th Feb, 2010 at 06:25:33pm
Not a clue, but he asked me wether it was for street or race... On 9th Feb, 2010 joeybaby83 said:
11th Feb, 2010 at 07:11:35pm
What defines a 'street motor'? Not keeping the revs between 4000-7500rpm continously at a guess
11th Feb, 2010 at 07:12:54pm
Well I have a race motor then built like a street motor On 26th Oct, 2004 TurboDave16v said:
14th Feb, 2010 at 04:52:52pm
I spoke to my machinest about this the other day, took the standard pully down and he said it should be fine.
14th Feb, 2010 at 06:10:52pm
If a race motor is built well, as in balanced properly, then it doesnt need a damper (as much). Swiftys and Slap Heads Miglias dont run dampers and win many races after thumping round a track flat out for 20 mins.
I seriously doubt it! |
1425 Posts Member #: 690 Post Whore Norfolk |
14th Feb, 2010 at 07:28:21pm
4cyl in line motors generate lots of torsional vibrations along the crank, ending up atthe crank damper whose job it is to ease the pain on the crank - how does it do it?
If Carling made Mini engines
14th Feb, 2010 at 08:55:17pm
John,
15th Feb, 2010 at 10:56:11am
Jean - I know many many people have done it and are happy with it but be in no doubt you will get random and varying spark scatter - especially just before and after the natural frequency of the mass, I'd have to do the maths but I'd expect the mass to rotate easily 5 degrees on its outer edge this is quite a distance.
15th Feb, 2010 at 10:59:36am
On 15th Feb, 2010 johnK said:
Jean - I know many many people have done it and are happy with it but be in no doubt you will get random and varying spark scatter - especially just before and after the natural frequency of the mass, I'd have to do the maths but I'd expect the mass to rotate easily 5 degrees on its outer edge this is quite a distance. JK i seem to remember this been done before and the difference falling within the megajolt / squirts own accuracy tolerance, go to find the thread Yes i moved to the darkside |
15th Feb, 2010 at 08:17:31pm
There are a few posts discussing it on page 1 of this thread:
15th Feb, 2010 at 09:31:33pm
As I've mentioned I'd have to do the maths to work out how much it moves but I did design chassis/drivetrain mass dampers for Nissan/Ford/Audi for a living for a number of years,believe me you can expect more than 0.5 degrees of movement at 5000rpm or so when a 0.5/0.75kg mass reaches resonant frequency - truth not fiction or guess work
15th Feb, 2010 at 09:36:39pm
Funnily enough John, I had thought about this, and was consdering the posibility of moving the crank picup to the flywheel at some point.
15th Feb, 2010 at 10:15:09pm
When you consider our poor little 3 bearing cranks probably twist, end to end, at least 2° in stock oem applications never mind you boys throwing 250+bhp through them or 8500rpm and the frces involved- makes you appreciate how hard that little crank damper has to work (by oscillating) to keep it all in one piece!
16th Feb, 2010 at 07:21:22pm
So what causes the taper on flywheel to vibrate and pickup on the crank?
16th Feb, 2010 at 07:33:56pm
On 15th Feb, 2010 mini13 said:
Funnily enough John, I had thought about this, and was consdering the posibility of moving the crank picup to the flywheel at some point. I had no idea of the effect but was thinking how many picups do you see on the dampers of production cars... all toothed wheels on production dampers are on the non-damped part :) i wouldnt run without one pure from the point of view they were fitted for a reason, and many people smarter than me decided on this reason :) i meen look how stingy bl are, for example, if they could have not fitted one they would have :) Edited by evolotion on 16th Feb, 2010. turbo 16v k-series 11.9@118.9 :)
16th Feb, 2010 at 09:48:29pm
Matty - the root cause is all the same - torsional vibration
16th Feb, 2010 at 11:08:01pm
John,
17th Feb, 2010 at 08:17:07pm
How many degrees of movement do you think could occur on the crank damper? |
17th Feb, 2010 at 09:11:56pm
The only real way to check it is on a dyno with a strobe
![]() 116 Posts Member #: 4273 Advanced Member stoke on trent |
17th Feb, 2010 at 10:14:02pm
i got the trigger wheel and damper for med, i asked then if i needed the damper and they said deffo put it on it will pro long the crack life so i got one |
17th Feb, 2010 at 10:17:35pm
