| Home > FAQ / Knowledge > exhaust back pressures... | |||||||
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
12th Feb, 2010 at 07:52:37pm
on a normal 5 port mini i know you need a bit of backpressure for best performance. but on a turbo is this different...
I popped my first one out the other day... |
12th Feb, 2010 at 07:57:20pm
well first off the "you need a bit of back pressure" is a bit of a misnomer, a decent sized NA exhaust allows an extraction effect (vacum)
12th Feb, 2010 at 08:08:51pm
ah ok. so a straight pipe wont harm the performance that much? ive got a maniflow 2" single box system at the mo so if there is not much difference i will probably use that, if not them ill give maniflow a ring to construct a pipe lol On 17th Feb, 2011 apbellamy said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
12th Feb, 2010 at 09:31:35pm
i ran a straight pipe in the past and will do when my alloy one turns up next week....lol,
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
13th Feb, 2010 at 10:29:17am
i want the noise... the neighbors are getting petty and and have started to take the piss by taking all but 1 of the parking spots at the back of our house, but my mini will be parked in the garage thats conveniently under there house lol. so noise is a bonus On 17th Feb, 2011 apbellamy said:
13th Feb, 2010 at 04:37:34pm
If you want my advice, speak politely to your neighbours and sort it out like adults. Once you fall out with them it can only ever get worse and worse.
13th Feb, 2010 at 06:20:22pm
Tom has a point, theres no point in pissing them of futher, On 2nd Oct, 2009 Vegard said:
14th Feb, 2010 at 12:45:23pm
![]() 161 Posts Member #: 6857 Advanced Member Lieto / Finland |
14th Feb, 2010 at 02:50:44pm
Now I must ask...
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
14th Feb, 2010 at 07:44:01pm
You don't need back pressure, what you need is something that maintains gas velocity. On a turbo this is not as big deal. On 13th Jul, 2012 Ben H said:
15th Feb, 2010 at 08:25:31am
On 14th Feb, 2010 Vegard said:
what you need is something that maintains gas velocity. Ok thanks Vegard, I think that I have done, then install correctly. Well, then sees it in the spring on the dyno. 1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
15th Feb, 2010 at 09:01:13am
Tom i run a free flow no box exhaust with no issue, its not that loud tbh. I even went to MOT with it as it is and he didnt bat an eyelid. There are far more chavved up corsas ect that are much more noisier than mine. It just sounds like a well sorted stainless N/A system. all be it with a little hint of whistle. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
