Home > General Chat > Slave cylinder
Mickey.h
Member #: 2240
Co.Cavan....Ireland
When i bought my metro turbo engine there was no slave cylinder with it,can somebody tell what type i need,verto or pre verto?
Bending the rules and ruling the bends,Since 1959
check the thread on the hose that would have screwed into it, IIRC verto ones are M12 (about 12mm) and non verto ones are 3/8UNF (about 9mm)
also is there a steel plate to mount it on on the clutch cover and a short arm, or does ot mount on the transfer case, and use a long arm?
Mickey.h
Member #: 2240
Co.Cavan....Ireland
I dont have it near me at the mo,but from a pic it looks to have a short arm.
could it not be a cable clutch.
Mickey.h
Member #: 2240
Co.Cavan....Ireland
I dont kno,thats why i said id ask on here!
ah ok,
if oit is a short arm it is verto, if the arm has no slot in the end and a rubber bush it is a cable clutch
Mickey.h
Member #: 2240
Co.Cavan....Ireland
Here's the engine.............
http://s807.photobucket.com/albums/yy355/minimanme/
Its a pre verto
Mickey.h
Member #: 2240
Co.Cavan....Ireland
Sound,i was told that,but said id double check!Cheers lads
