| Home > Help Needed / General Tech Chat > Megajolt/rolling road issue? | |||||||
37 Posts Member #: 8150 Member |
16th Feb, 2010 at 04:33:13pm
Hello,
16th Feb, 2010 at 04:38:36pm
what rolling road did you use? where are you based? |
16th Feb, 2010 at 04:43:34pm
I went to Sigma in Gillingham, Dorset. Wasn't particularly pleased with their attitude and service, they barely spoke to me and seemed quite dismissive. Fair enough if they couldn't do anything for me but they were pretty rude. |
16th Feb, 2010 at 04:56:49pm
im sure someone on here will point you to an alternative.. im miles away so have no idea where to send you. |
16th Feb, 2010 at 04:59:06pm
Ok mate no probs. So does a RR have to be megajolt friendly? I'm based in Yeovil, Somerset. I'm waiting to hear back from a garage called Performance 3000 to see if they think they could accomodate it. |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
16th Feb, 2010 at 05:03:38pm
I'd look at going to a Mini specialist if I were you mate. Slark arn't too far from you, and they are perfectly happy to setup megajolt, and have done many turbo minis in the past.....
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
16th Feb, 2010 at 05:03:59pm
yeah if you dont know how to read or adjust the map then the guys at the rollers will need to know what to do.
16th Feb, 2010 at 05:17:29pm
You need someone who knows the system in order to map it.
AlexF |
16th Feb, 2010 at 05:26:00pm
The previous owner gave me a disk with the car which I've only just remembered about, which was stupid of me. How will I know if it is the correct software? |
16th Feb, 2010 at 05:30:05pm
Brilliant, found the disk and looks like it is all the configuration software for the ignition (version 3).
16th Feb, 2010 at 05:37:10pm
No not by any means. As an analogy, it is like taking a Ford to a Volkswagen dealer. OK they will probably be able to change the brake pads for you, but they are not going to be able to plug into the ECU and program a new key to the car for example, because they don't have the right software, and connection leads.
16th Feb, 2010 at 05:45:39pm
Ok point taken. I'm going to contact Slark tomorrow as they sound great, wish I'd heard of them earlier! I now know the specifics of the ignition so hopefully I'll be able to get somewhere with them.
1050 Posts Member #: 764 Post Whore Staffordshire |
16th Feb, 2010 at 06:06:05pm
I believe slark will need you to take a laptop, software and lead with you. |
17th Feb, 2010 at 12:50:05pm
Where can I get a lead? |
17th Feb, 2010 at 12:55:27pm
Probably best to have a read of this:
17th Feb, 2010 at 12:57:55pm
Slark or Harris Motorsport should be able to look after your mappable needs If your in yeovil Steve Harris is only about 30 miles away. On 7th Oct, 2010 5haneJ said:
499 Posts Member #: 2257 Senior Member Brighton |
17th Feb, 2010 at 12:59:29pm
I have the serial to rj whats it cable.
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
17th Feb, 2010 at 01:49:38pm
Steve Harris near Ringwood - 01725 517999 or
17th Feb, 2010 at 02:01:22pm
Worth noting that if you don't have a laptop irs worth looking for an older one. Mine is About 10 years old, runs win 95 and is perfect for mj as it has a serial port build in. |
17th Feb, 2010 at 03:51:02pm
Thanks for all your help guys this is great. I did phone Steve Harris Motorsport a couple of weeks ago, he said he couldn't get me in for 6 months! |
301 Posts Member #: 2480 Senior Member Swindon |
17th Feb, 2010 at 05:03:14pm
Give Neil a call at Slarks. As far as im aware he has the cable and a laptop (but dont quote me on the laptop!) Used the cable on mine the other week feature=mhum |
