Home > Show Us Yours! > Willowbank Autocross Video
MadMatt
Member #: 105
Brisbane ,Australia
My buggy & a couple of my mates at the Willowbank Autocross last sunday
Gaz is in the purple thing & Stew is the mello-yello thing
sorry the vid is so shit,,, I couldn`t sort out the editting bit so i just shoved it all on there
http://www.youtube.com/user/madmatttheminiman
Buggy was 3rd fastest laps outright,,, there was 45 competitiors,,, lots of 4x4 turbo rally cars there, wrx`s, Sti`s & Fords etc... only the 2 Mitsu EVO-9s just a tad in front of me,,, but i`ll fix that next meeting
One standing start lap, on dirt, then a flying lap.
I still havn`t sorted my left-foot-braking yet,,, very messy so i gave up on that for the day--> (peddles are being modded as i speak) & it`s way way way too tall geared for any decent standing start, so i`ve already found a 13tooth front Colin,,, ah er... i mean front "Sprocket", so i can throw away the 15 tooth one then i`ll start much better-er also fitting much wider front rims (with bead-locks) to get the tyre to sit flatter & not buldge so damn much , drop even more pressure out of them & more grip means more go-forwards
Edited by MadMatt on 17th Feb, 2010.
www.miniman.com.au
Nice, that thing is crying out for a tarmac surface. Then all hell can be unleashed:)
On 7th Oct, 2010 5haneJ said: yeah I gave it all a good prodding
MadMatt
Member #: 105
Brisbane ,Australia
yeah i`m hanging to get it out to Lakside Raceway with the slicks on it, Mt Cotton & Grafton & Mt Cootha & Noosa Hillclimb meetings to come soon too
Ive moddified the brake peddle to be more "left-foot" friendly now, i`ve also extended the throttle peddle cause some times i was missing the damn thing completely around the autocross track
I now have a 200hp engine option , still in n/a form & i`m thinking of grabbing it
I just don`t think the turbo would do this can any justice at the moment.,. maybe later when i`ve got more of a handle on it
My neck is still sore from last weekends race
www.miniman.com.au
MadMatt
Member #: 105
Brisbane ,Australia
ok,,, 3rd fastest time again last meeting,,, i made a few small changes before the event & they definately helped,
I zipped up the gear ratio a tad,,, softened the front end & stiffened the rear end, made my brake peddle a bit more accessible for my left foot & all made it faster & easier to drive, so now i`m only a bees-dick away from fastest time outright
But!!! Iv`e decided to make it even easier for me to accomplish that,,, with a bit of thought (& quite a few drinkies i might add) i`ve decided to make it 4x4
Now it`s not so hard to do actually,,, i`m going to take the front diff assy out & shove it in the back,,, make a new front diff assy with 2x sprockets (side by side) & run a chain from the 2nd sprocket to the rear diff.
chain will run half under the car (through nylon square section tube) & then run back to the front via above the floor pan (again through another square section nylon tube , but with thick "Hat" shaped steel cover/housing.
The WRx`s & Evos are getting 1&1/2 secs on me just off the start line within the first 60ft & i`m chasing most of that back during the lap, but i figure it will be easier if i`m 4x4 & turbo too
watch this space for the new "Improved" version,,, turbo 4x4 R1 "thing"
Any thoughts on ratios between front & rear diffs?????
http://www.youtube.com/watch?v=k-mwAYsytWo
Edited by MadMatt on 27th Apr, 2010.
www.miniman.com.au
Matt, crazy car but please make a tripod for your camera man before you go 4wd, feel sea sick watching that video lol
MadMatt
Member #: 105
Brisbane ,Australia
yeah i know, He used to be really good at it years ago, but hasn`t done it for ages,,, he`ll warm back up into it i`m sure
I`ve started building the new front diff assy & cradle,,, we have ideas about the rear arms , making them accept cv joints & wheel brgs etc
so we`re on the way
www.miniman.com.au
are you binning the such drive then?
we had trouble finding front sprockets that were compatible?
MadMatt
Member #: 105
Brisbane ,Australia
Keeping the LSD front diff, just adding another sprocket to it to drive the rear end
Taking the moke rear arms off & replacing with 45mm hollow go-kart axle, held in place by 2 pairs of self cetering go-kart rear axle bearings & their respective billett alloy retainers sandwiching a 10mm thick alloy plate inbetween each pair for the plates to become the uprights, swing the rose-jointed, 4-link, with watts-link lateral assy & coil-over shock mounts onto,,, one decent size disc brake rotor & alloy Willwood caliper attached to the right rear bearing/up-right assy, & then add the 530-13t sprocket & carrier next to the left rear bearing/up-right assy , throw some 8ft of chain at it,,, & tensioner assy & we`re done,,, pretty easy cause i already have most of all that here
i had front sprockets made in (530) 13t & had the center cut by CNC-EMS hot wire cutter for the internal spline, only because yamaha don`t make a 13t front in 530 to fit the R1
easy-peasy & cheap as chips ($140 for 2 of them),,, & the same mob is making me up 3x 530-42t sprockets & 2x tensioner/roller Colins,,, ar,,,er,, "sprockets" at the moment)
I`m feeling like the extra drag of the rear chain & guides etc & also the 4x4 """"traction thing"""" may suck a bit too much power for my liking so we have a little Hair-drier to fit onto the thing after it`s all running with the 4x4 gear fitted & (hopfully) sorted out any handling issues
But for now i`m running it as it is at the next meeting on the 16th of May,,, then ripping the front diff out to add the 2nd sprocket & shove it straight back in & run it again next month,,,, & after that meeting i`ll throw the steering & seat & cage up 100mm & lay in the rear chain guides,,, then run it again the folling month,,, then by that time i reckon i`ll have the rear end sorted & ready to fit,,, so maybe in a few months,,, give or take a month or 2 for surfing holidays (3 weeks in Byron bay leaving this thursday for starters)
It`s a hard life hey???
Edited by MadMatt on 1st May, 2010.
www.miniman.com.au
Users viewing this thread:
none. (+ 1 Guests)
