| Home > Beginners Tech > What would be needed to do this...... | |||||||
![]() 32 Posts Member #: 8323 Member Bedfordshire |
17th Feb, 2010 at 03:51:55pm
Austin Mini Designer Stage 1 N/A 1098
On 31st Oct, 2007 DemonPixie said:
Well I think you're all a bunch of nutters.... |
17th Feb, 2010 at 03:53:45pm
(this is what i have been told by a mate) Austin Mini Designer Stage 1 N/A 1098
17th Feb, 2010 at 03:56:51pm
Looks pointless to me. It's just a Maestro plenum with an air filter attached to it.
17th Feb, 2010 at 04:04:46pm
i have been told (by burnard) that it induces more air flow but i dont believe a word, i am looking for a t3 turbine anyway Austin Mini Designer Stage 1 N/A 1098
17th Feb, 2010 at 04:24:36pm
Painted engine steady is interesting... |
17th Feb, 2010 at 04:27:02pm
And everything else by the looks of it Gav If something is worth doing, it's worth doing half of. |
17th Feb, 2010 at 04:34:34pm
what would it acctually do then with a maestro plenum and filter with flexy hosing?? Austin Mini Designer Stage 1 N/A 1098
17th Feb, 2010 at 04:35:32pm
That really is wank. In the 13's at last!.. Just |
17th Feb, 2010 at 04:37:52pm
Now that is not it, but there used to be a similar thing available called a Torquemaster, apparently the extra induction length did boost torque on certain NA engines. I think its in Vizards book.
17th Feb, 2010 at 05:16:18pm
Is that the engine that was on ebay a while back that been dropped in a vat of blue paint? On 11th Feb, 2015 robert said:
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
22nd Feb, 2010 at 09:52:24am
bulkhead and rocker cover look nice. both the breathers are going to each other too On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
22nd Feb, 2010 at 10:01:15am
There is a Tee piece jams from the breather pipes going into the carb. If something is worth doing, it's worth doing half of. |
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
22nd Feb, 2010 at 10:03:37am
did janspeed do one aswell? i might be way off the mark.
On 17th Feb, 2010 Tom Fenton said:
Now that is not it, but there used to be a similar thing available called a Torquemaster, apparently the extra induction length did boost torque on certain NA engines. I think its in Vizards book. On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
22nd Feb, 2010 at 10:10:40am
I think the Torquemaster was made by Janspeed.
22nd Feb, 2010 at 10:19:08am
22nd Feb, 2010 at 10:31:25am
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
22nd Feb, 2010 at 09:35:48pm
You sure Tom ? thought it was the Osselli Torquemaster - had one fitted to a 998 ages ago.
On 22nd Feb, 2010 Tom Fenton said:
I think the Torquemaster was made by Janspeed. Edited by turbominivanman on 22nd Feb, 2010. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
172 Posts Member #: 1600 Advanced Member Portsmouth, Hampshire |
22nd Feb, 2010 at 10:33:04pm
there was a mini limo with the same setup, but it only to reduce induction noise away from the cabin |
23rd Feb, 2010 at 08:57:17am
i like the way the engine bay been de cluttered but apart from that i agree its pointless Crystal Sound Audio said:
23rd Feb, 2010 at 09:17:20am
The oselli Torquemaster was an inlet manifold wasn't it?
23rd Feb, 2010 at 09:21:49am
If it had an air-box on the end instead of that cone filter it would reduce noise. I must admit it looks pretty tidy. If something is worth doing, it's worth doing half of. |
