Home > For Sale > 1275cc Metro Engine
The engine in my Sprint will soon be comming out to be replaced by a 998 turbo, the following will be for sale.
Engine -
Including - Head, cam and all drive parts, flywheel housing and wok (but will have been removed)
NOT including - gearbox, flywheel and drops, flywheel pulley or any other perifferals such as starter and alternator. I don't use a dizzy but can supply the drive and dizzy and clamp that came with the engine, not sure on condition
Also included in the sale are the carb (HIF44) & manifold, the Cooper freeflow exhaust manifold, and complete single box RC40 system.
The engine is currently installed in the car and runs perfectly, I use it every day, it uses no oil and had grat oil pressure, but does leak a bit from the pulley and rocker cover. It's a 100% useable engine
In theory it will be removed from the car sometime next month, if you want to see it running before then that's fine.
I live nere Harrogate, but could potentially get it to Melton Mowbray or Crewe.
I'd like £400 for the lot, but am open to offers.
Remember the engine is not available for a month at least, I'm advertising now so it can be viewed running.
I'll swap it for a 998 short engine *happy*
