Home > General Chat > dump valve
nibble36
Member #: 4273
stoke on trent
hi all will this make any diff as the pipe i want to use is a bit bigger than the small silicon pipe that came with the vavle
standard pipe
my pipe
both the pipes
thanks nibble
none trhat will be fine.
my bailey used to seize like a bitch all the time,
something to do with fuel vapour or sumit.....
ministef1
Member #: 1791
Cranleigh, surrey
yes mine used to chatter a lot!
"Cars are a lifetime of pain"
The seal on the piston swells and sticks. In my case it split too.
You need to mount then like shown or upside down to minimise the problem. Mine seem ok.
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
what king of problem??
can any one help, i do not know where to connect that pipe which goes out of DV?? or it just stays open?
Nothing special!
into the manifold,you may need to make a take off,
do you have a boost gauge?
if not get one, if so then you can tee off from the feed that goe's to that...
kenny2
Member #: 5362
wexford in ireland
probably a stupid question but where does the feed for the boost gauge come from? and where does the boost controller feed come from and go to? sorry for bein thick!!
On 5th Jan, 2011 wolfie said:
from the manifold,
and the bleed valve T's between the actuator and the turbo
