| Home > Help Needed / General Tech Chat > Next little problem... am i ok with solid engine steady mounts at top | |||||||
18th Jan, 2005 at 12:05:18am
hi there, sorted the timing thanks for all your help, cars running alot better im really glad to have it back and will never sell it again. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
Site Admin 6302 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
18th Jan, 2005 at 09:58:13am
My old 1275 killed the yellow poly mounts in 20 minutes, gotta be a record? - anyway, i replaced them with standard ones, and fitted an ultimate engine steady, and after that it was great! - no engine movement at all.
Edited by AlexB on 18th Jan, 2005. |
568 Posts Member #: 102 Post Whore Pennsylvania USA |
18th Jan, 2005 at 10:32:40am
Thats what I used and it sorted all engine movement. Its as solid as a rock. |
18th Jan, 2005 at 11:20:53am
Never really believed in bottom engine mounts.
291 Posts Member #: 48 Senior Member Leicester |
18th Jan, 2005 at 11:53:08am
I have the solid nylon type bushes in the engine end of the standard steady it's too noisey with them on the bulkhead end so I use standard rubber bushes at the bulkhead end
216 Posts Member #: 370 Reads "my mates" max power whilst wearing my Mrs's underwear |
18th Jan, 2005 at 01:03:37pm
i only have one engine steady, its the avonbar one that bolts to the water pump, it holds the engine in place very well, but it restricts access to the turbo inlet, it was murder trying to run the air pipe to the turbo, also its no good if you cut to much bulkhead away, i just about got away with it.
21st Jan, 2005 at 01:02:14pm
my down pipe is now blowing, does this happen due to engine movement?
21st Jan, 2005 at 01:04:55pm
In your last post you say you are only running one steady, that bolts to the water pump? If so put the standard one back as well that goes from near the master cylinders to the side of the block, with a combo of both in good order I would be suprised if you engine moves much at all??
21st Jan, 2005 at 01:07:34pm
tom, i would love to do that but the original seized, so out came the grinder and chop!
21st Jan, 2005 at 01:10:08pm
which end? at the bulkhead end? the plate under the master cylinders isn't that hard to change, and you can easily make up a new section to weld on the body out of a bit of angle iron.
21st Jan, 2005 at 01:22:48pm
blocks fine its the bulkhead bracket that i cut, i think you may have to change the turbo oil feed if using this steady according to what i've read some where on here.
21st Jan, 2005 at 01:39:28pm
If you are using the metro oil feed pipe then yes you will need to change it to a braided flexible one to use the original steady. Most people opt for the braided one as a matter of course I think.
21st Jan, 2005 at 02:39:26pm
ah yes good point, well i think i will give the bottom one a try first, even though i do agree with what your saying, its just that im a lazy chuffer, and if it dont do bugger all then i will have to do what you say, the engine is rock solid on the side of the water pump its just the other side, thats why i wont somthing on the drvers side. |
21st Jan, 2005 at 03:03:09pm
i had the standard steady bar fitted on mine while i was using the solid oil feed pipe, it was close but didnt get in the way at all. On 20th Oct, 2015 Tom Fenton said:
21st Jan, 2005 at 03:22:26pm
i think i should of changed the engine mounts to be honest when i had the motor out, but you know what its like, cant wait wont wait got no money lol,
22nd Jan, 2005 at 01:01:50am
you can undo some of those bolts fine, ive had 2 of mine out at once with no leaks |
