Home > Help Needed / General Tech Chat > Mounting placcy windows in the doors
Just wondering how you folk have gone about it?
I was going to use the original rubbers, slide the window up into it, wedge in place then fix it there somehow? anyone have any suggestions?
When i fitted the alloy skins, i did away with the reinforcement panel that sits flush/spot welded against the top of the original skin, so cant use that
Joe
I did exactly that. 3 bolts at the bottom.
Why not use the rail on the inside to bolt the window in place? I used 3mm bolts, and 5mm nuts as spacers.
Vegard, have you ever put any decent pics up of that car?
I think you should
cool, will proceed down that route then
nic, i think V has a racer thread somewhere with a few good pics
There are some good vids of it on the track too
Advantage
Member #: 1450
Near Paris - France
+1
Vegard, you owe us a complete build thread !
Rusty by nature
http://home.online.no/~lyngset/71gt.cfm
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
While this tread's current, is the opening sufficient to stay cool on a hot summers day? I know that's highly subjective but I'm probably in need of new runners on the window bottoms anyway (~£50) vs getting a set of [polycarb?] windows as above.
Cheers, Dave.
Edited by Pottsy on 2nd Mar, 2010.
