Home > General Chat > Water Pump Shock
Metro Mandy
Member #: 7724
West Midlands
Hi fellas :)
I've spent past few days figuring out why my A series Metro has been overheating. Previous owner never cured fault despite apparantly changing thermostat. Anyhow replaced that as well as broken fan switch to no avail. All water pipes were getting hot apart from one going to and from the heater. Checked for blockages and found none.
Anyhow, disconnecting pipe from top thermostat housing proved that no water was pumping through at all so figured maybe water pump was ineffective. So removed water pump and was quite shocked to find that the rotor blades have virtually disappeared!! Fitted new water pump now and running great. Thought I'd show you guys a photo of the damaged pump though....
Suck, squeeze, bang, blow........
how cool is that ...um in an ,uncool way of course.
I know what Vegard is thinking *hehe!*
so where did that go then ?
Blimey Charlie, still it's light weight.
*surprised* not good
stefaz
Member #: 1656
stoke-on-trent
That's pretty bad, also awaiting viking comments about pink liquid
MarkGTT
Member #: 1194
Shropshire.
have you found the rest of it yet?
Metro Mandy
Member #: 7724
West Midlands
No idea where its gone to!
Whats Vegard and pink liquid then??
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Haha, that's brilliant
On 30th Apr, 2010 Rod S said:
Gary's description is best
Did you flush the block and head out?? Personally I'd be spending a fair amount of time making sure the missing bits of impellor wern't inside your engine.
