Home > A-Series EFI / Injection > DTA engine managment.
Rick.SPI
Member #: 8027
hi, im going to be using DTA on my new turbo engine when its finished, i love the sound of it and it dosnt have to run an edis pack it just has coil to plug which aparently creates a lot better spark.
just wondering if any1 here has used it, and any feedback on it.
Cheers.
Prawn
Member #: 5232
basingstoke
why DTA in particular Rick? you're not running EFI are you? so you'd just be using it for spark?
Rick.SPI
Member #: 8027
yep just engine managment, no fuel injection, but it has some very good specs. just wondering if anyone has any experience with it, another advantage of it is that a lot of RR's will know the system well as its used alot in pretty much all makes of car.
Edited by Rick.SPI on 7th Mar, 2010.
Waste of money on a 5 port engine using a carb.
Rick.SPI
Member #: 8027
any reasons for this?
PaulH
Member #: 2340
Dublin Ireland
and its a PIA to wire and the people who make it are not at all helpfull when anything goes wrong trust me been there done that bought the T-Shirt
On 17th Feb, 2009 Rob H said:
Rick.SPI
Member #: 8027
did it work good when it was working?
Prawn
Member #: 5232
basingstoke
there are plenty of other systems out there that are much cheaper and more widely used in Minis.
Things like emerald, and omex are used much more regularly, as well as of course megajolt and megasquirt for a fraction of the cost....
PaulH
Member #: 2340
Dublin Ireland
NO
I use a DTA on one of my cars, and have found it to be fine. However as you cannot use the fuel side on a 5 port you may as well save the dosh and use a MegaJolt.
Rick.SPI
Member #: 8027
ok, i will have to do some price comparisons and see how much all the different options are, thanks :).
8PortChris
Member #: 246
Cumbria
You can get the DTA S40 Pro in an ignition only version
Rick.SPI
Member #: 8027
i thought that was the case but im not sure to be honest, and liked the idea of not using an edis. however im still to find out the prices yet and the details, i shall have a ring tomorow and see what is on offer and at what price compared to other makes mentioned, obviously megajolt has the big advantage of the amount of mini's using it, so it is proven.
http://www.dtafast.co.uk/S_40_PRO.htm
some of the features on there are amazing, but can they be used if your still running a carb?
obviously it all depends on price aswell.
martin is running it on his turbo and has it set with launch conrtoll and some other facny stuff and i think his is still carbed.
does megajolt offer all these sort of functions?
sorry i really am a noobie when it comes to engine managment...
The S 40 will not do the coil on plug. It will still need a wasted spark coil.
I'm biased towards Megasquirt because that what I use. That will do all you need and more, plus you can save a bit of money by building it yourself and learn a lot as you go.
Even with a carb you can have coil on/near plug, launch control, boost control and even traction control.
Most ECUs can do this these days but they are expensive.
However, if you have not used anything like this before and are not familiar with electronics, then start with a Megajolt.
Leave the DTA to the bench racers in the pub.
Rick.SPI
Member #: 8027
haha :) liking the bench racers comment.
ok thankyou for the info its much apreciated :)
do you have a rough idea on the price of a megasquirt/jolt system if i get all the edis stuff myself?
01smartc
Member #: 2563
Tamworth
I use DTA and its very good for what I want (bmw k1200 on injection) .. the ignition only kits also work very well on carbed engines.. lots of features you can use and easy program to work with.
Wiring not too difficult just a bit fiddly with the small connectors!
IMO megajolt just doesnt have the features or accuracy of the DTA software. And as you said alot more rolling roads deal with DTA more than Megajolt... including ourselves.
Chris @ Smart Performance
Rick.SPI
Member #: 8027
really conflicting view here then...
but is it still the case that DTA is alot more expensive than megajolt?
01smartc
Member #: 2563
Tamworth
Yer alot more expensive. But in my view, you get what you pay for :)
Rick.SPI
Member #: 8027
thats a fair comment.
tadge44
Member #: 2500
Buckinghamshire
My RR operator recommends Polestar and this is a stand alone system requiring only the usual coil pack.
IIRC there are only five wires to connect and then the sensor to mount and a "chopper" plate on the front pulley as with the toothed wheel for MJ.
The greatest advantage is that the ignition map can be adjusted with the engine running on the dyno so results can be seen instantaneously _ I cant do this with my MJ V3 although I dont know if later versions can.
Any comments/experiences with Polestar ?.
Cost is an issue because, with a Map sensor, its about £550
DTA is very good, and you have various models to choose from to satisfy your needs.
Personaly I would be wanting more from it than just the ignition side.
VEMS on the otherhand would give you wideband, EGT and coil on/ near plug in with the price. There was a chap on the continent that has done just this on a Turbo Mini, somewhere.
Oh and not forgetting dual config, and SD card logging as an optional extra
I am biased towards VEMS as Paul is biased towards Megasquirt :)
Edited by Sprocket on 8th Mar, 2010.
It's a case of what you have got used to and learnt how it works.
I've spent ages (and a lot of cash) learning Megasquirt. That doesn't mean it's the best but it does mean I know what it can do and how I can make it do it.
I would say, look across all the forums (not just TM) to see who is using what you are thinking of and see how they are getting on.
Scruffy
Member #: 328
Seaford Rise, South Australia
On 5th Sep, 2011 Vegard said:
jbelanger
Member #: 831
Montreal, Canada
Features are easy to compare but I'd like to know what you used as a basis to say that the accuracy is not as good other than the fact you paid a lot of money for your DTA
Of all the alternatives presented here I doubt any would have an advantage (or disadvantage) in terms of accuracy for the ignition timing. So let's keep it to facts that can be checked please.
And I'm not saying that one is better than the other since it basically comes down to personal choices taking all facts into account. But saying that one must better because it's more expensive is useless at best.
Jean
http://www.jbperf.com/
Rick.SPI
Member #: 8027
are you running DTA scruffy?
