Home > Help Needed / General Tech Chat > 1098 12g940 questions
after searching on a few forums i cant find what i want so ill ask here ...
has anyone used the 998 head gasket on a 12g940/1098 block combo ?
has anyone used this combo ,without modifying the waterways as per our kieths advice page on it . if you did, which gasket did you use ?
thanks
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Yes. i used to drive a mini 1098 with a 12g940 head. N/A
You need to use the head gasket from the head (big bore gasket). No other modification.
watch out fore the exhaust valve overhang.
I had absolutly no torque below 2500 rpm, but from 3000 it was pulling strong.
Good luck
Tom
If i have more toys than you when i die, I WIN
You can just slap it on using a large bore gasket with no modifications. But what eventually happens is that the surface of the block gets damaged around the fire ring by the water. So it's worth doing the mod to the block.
All you need is an 8mm tap down the holes in the block and sink in a bolt and cut off flush. A bit of thread lock or epoxy will seal it nicely.
Put thet large bore gasket on the block, you'll see the two ater holes in question.
thanks chaps ,lots of good info ,although not actually answering my questions.. *wink*
BK450
put that in your pipe and smoke it...
On 9th Mar, 2010 rubicon said:
BK450
speaking of smoking ..going to next rr day ?
*happy*
yes i will be...... hopefully with honda power.....
BK450
No because you can't
I did it with no block or had mods to the water ways, it works fine, but eventually you will damage the block face (I said this above).
Any large bore gasket will fit.
Does that help?
Does that help?
not really will , i wanted to know if anyone has done it ,this chap seems to have done so ,so i was looking for further validation ..
I thought you might be interested in reading this web page:
http://www.theminiforum.co.uk/forums/index...showtopic=33436
perhaps you could tell me why it doesnt work ,you obviously looked into it to be so certain , what problems will the chap in the thread experience ?
Edited by robert on 9th Mar, 2010.
With a 998 gasket, the inner fire ring overhangs the combustion chamber, doesn't it?
Great idea!
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Great idea!
Yes you seem to think so, at least on one head I have seen *tongue**happy*
Great idea!
A while ago? *wink*
miniminor63
Member #: 672
Oslo, Norway
yes, I did not say it wasn't *wink*
It worked nicely the time I had it though :)
Edited by miniminor63 on 10th Mar, 2010.
tell me more about this engine mm63?:)
ooops ... um ,another question ... how close has anyone gone to the oil hole when skimming the head ?? *oh well*
1mm on a 202 head.
miniminor63
Member #: 672
Oslo, Norway
Robert,
Nothing exotic, just a 1098 road engine with a bit too aggressive porting making the chamber larger than the hole in the head gasket :)
On 11th Mar, 2010 Vegard said:
1mm on a 202 head.
ah brilliant thanks vegard ,a scholar AND a gentleman.
1mm on a 202 head.
My pleasure. However, Vizard states that he likes 10thou if I remember correctly, but I've done several to approx 1mm and it seems to work.
yes the 2 viz books i have say 60 thou , i ported a 998 head ,and needed 101 thou off to get 10.25:1 , then found the oil hole was already at 80 thou ..
still ,40 thou off will get me to 9.55:1 so not to bad with a 270 cam on a 1098.
998turbomini25
Member #: 2276
sheffield / derby
i'm not sure how much this 12g295 had removed, but i can say it was definitely to much, as it melted whilst running on the dyno!!
blimey look at that ,how thick is the deck from the oil hole on that ?
