| Home > Help Needed / General Tech Chat > vacum on boost? | |||||||
39 Posts Member #: 444 Member |
19th Jan, 2005 at 12:02:09am
ok so possibly the dozyest question i have ever asked a forum but it is just something i dont know |
19th Jan, 2005 at 12:15:42am
well how many times do you brake on boost??
19th Jan, 2005 at 12:26:17am
Yes when braking you will be off boost normally so servo will see vacuum to assist your pedal effort. However if like me you like to left foot brake then you will find left foot braking while on boost will cause a hard brake pedal. Easy way round this if it bothers you is to junk the servo and use a non-assisted master cylinder.
![]() 127 Posts Member #: 439 Advanced Member derbyshire |
19th Jan, 2005 at 07:39:32am
yes vacuum comes off boost, same vacuum that ttssshhh the dump valve, servo pipe shud have its one way valve close to the inlet as poss so to create a short pipe to vacuum rather than a long one,
19th Jan, 2005 at 10:17:17am
sorry forgot the most relevant element to me i am running a super charger will i still see a vacum when decelerating? |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
19th Jan, 2005 at 10:09:41pm
Yes you will so long as it's plumbed up correctly.
21st Jan, 2005 at 10:16:07am
cool thanks for the info |
21st Jan, 2005 at 12:38:09pm
your servo has a reserve of about 3-5 stabs at the pedal, so it should be ok even on left foot braking :)
AlexF |
21st Jan, 2005 at 01:20:37pm
do the peeps on this board recon a servo is worthwhile |
21st Jan, 2005 at 06:50:18pm
I run one :)
AlexF |
22nd Jan, 2005 at 08:11:01am
i ditched mine, i never liked it, plus i'd snapped a mounting bolt for it so the MOT man always gave me a dodgy look if he noticed it. it does take up a lot fo room aswell, makes it even harder to get my fat hands in the engine bay. On 20th Oct, 2015 Tom Fenton said:
