| Home > General Chat > Gearbox rebuild problems/questions (1st motion shaft)?baulk rings | |||||||
9th Mar, 2010 at 09:23:03pm
9th Mar, 2010 at 09:42:23pm
also, iv not had chance to look, but are a and a+ selectors interchangerble? thanks |
9th Mar, 2010 at 09:49:44pm
Can we have some decent pictures that show the parts you are talking about in full focus Please. All I can see is the floor.
9th Mar, 2010 at 09:54:38pm
il try to get a few tomorrow. it was the oil on the parts messing the reflection/focus up |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
9th Mar, 2010 at 10:06:18pm
If you have a macro setting on your camera this will help for close up's. usually a little flower on one of the arrow buttons. Also have a neutral/plane background. not trying to be patronizing if you know this already.
9th Mar, 2010 at 10:08:23pm
no, im crap with phones/computers etc. my phone doesnt work half the time! |
9th Mar, 2010 at 10:47:41pm
does anyone know if a series selector forks can be changed with A+. may change them for some known good ones whilst its apart if they are compatable? as i said baulk rings seemed to look ok, so trying to rule out the cause. thanks |
9th Mar, 2010 at 10:53:38pm
Fit the syncro ring on the cone. If there is less then 0.8mm clearance between the ring and the face where the dog teeth sit, the ring or gear is junk.
10th Mar, 2010 at 10:02:53am
thanks for the input. will measure up later and hopefully get something sorted. only problem is that the 1st motion is the close ratio gt type, therefore nla? |
10th Mar, 2010 at 10:46:31am
On 10th Mar, 2010 welshdan said:
thanks for the input. will measure up later and hopefully get something sorted. only problem is that the 1st motion is the close ratio gt type, therefore nla? I guess you could have the gear recoated in some way? If the dog teeth are in good condition and the bearing surface inside, why not? Why not approach Tran-X and throw it in along with all the SC ones they make?
11th Mar, 2010 at 12:51:03am
thanks, was thinking along those lines. hopefully have things sorted for now.
11th Mar, 2010 at 09:28:23am
Raised areas on the baulk surface is probably what's left of the coating - new rings won't help much (if at all) and certainly not for long. |
11th Mar, 2010 at 07:55:43pm
well looks like you have covered most areas, how ever i would check on the clutch set as well as lack of clutch thorw will cause all the stated probs to, but hopefully the new rings will sort it out. always looking for them bigger bunches of bannanas |
12th Mar, 2010 at 07:45:37am
On 11th Mar, 2010 graemec said:
Raised areas on the baulk surface is probably what's left of the coating - new rings won't help much (if at all) and certainly not for long. I agree. Refitting this 1st motion shaft is like peeing in your pants. On 13th Jul, 2012 Ben H said:
12th Mar, 2010 at 07:52:53am
you will still have a non syncro fourth gear that is for sure...
12th Mar, 2010 at 12:07:57pm
dan, im out of action at the mo with a bad back, but i have an 's' close ratio box in stores that needs a rebuild (bought off ebay as spares) ive never had a close look at it as bought a straight cut gearbox off turbotim instead, so dont know off the top of my head the condition its in
