| Home > General Chat > brace between the two rear arches | |||||||
14th Mar, 2010 at 08:28:32pm
Hi, has anyone added a brace between the two rear arches? if so how and do you have any pics?
14th Mar, 2010 at 08:30:10pm
I'm going to when I turret my arches for coil overs, but obviously haven't started that yet! On 7th Oct, 2010 5haneJ said:
14th Mar, 2010 at 08:31:43pm
yeah should have stated on standard arch set up.. |
203 Posts Member #: 479 Senior Member |
14th Mar, 2010 at 08:40:37pm
14th Mar, 2010 at 08:42:57pm
Thanks, is that a tube welded directley to the arch or did you make some kind of bracket up? |
14th Mar, 2010 at 08:54:40pm
http://i21.photobucket.com/albums/b256/adv...98/P1180082.jpg
14th Mar, 2010 at 08:55:07pm
Just welded directly.
14th Mar, 2010 at 09:00:28pm
cheers chaps.
![]() 300 Posts Member #: 1746 Senior Member Kent |
14th Mar, 2010 at 09:22:02pm
Iv got one on my clubman estate, but i have just welded the bard directly between the top of the turrets.
14th Mar, 2010 at 09:50:45pm
I intend to weld in a bar between the two rear arches, on the inside of the cabin, more as a harness bar than anything else. I was going to drill a hole in each arch for the tube to pass a little through for better support On 26th Oct, 2004 TurboDave16v said:
15th Mar, 2010 at 10:58:41am
so is it a good idea to brace this if the boot floor is changed or will it not make much difference?
15th Mar, 2010 at 11:15:01am
Thats why I'm intending to weld the bar between the two turrets, to keep it all rigid.
15th Mar, 2010 at 11:49:49am
15th Mar, 2010 at 11:57:52am
thats alot of rear camber mike Edited by Brett on 15th Mar, 2010. Yes i moved to the darkside |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
15th Mar, 2010 at 12:32:31pm
I was planning to brace it that much, go for what is basically a spaceframe with a non-removable body In boost we trust |
15th Mar, 2010 at 02:19:34pm
Yes brett shes puckered up tighter than a snare drum! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
1425 Posts Member #: 690 Post Whore Norfolk |
15th Mar, 2010 at 03:00:00pm
To complete the effect tie the brace bar into the floor/strong structure or you'll just make a big parralelogram (sorry about spelling) which will flex about rather than stiffening the arch structure up.
If Carling made Mini engines
15th Mar, 2010 at 04:33:31pm
Mike - that looks great, will see if i can achieve something similar
