| Home > Help Needed / General Tech Chat > Paint resistiveness | |||||||
283 Posts Member #: 8215 Senior Member Rayleigh |
14th Mar, 2010 at 10:41:47pm
Hello,
Edited by Custard on 15th Mar, 2010. Dave the Cake |
14th Mar, 2010 at 10:59:59pm
Celulose gets tacky as it gets hot, no surprise as its a solvent based paint. 2K paint is a thermoset paint and much more resilient to pretty much everything celulose is not. On 26th Oct, 2004 TurboDave16v said:
15th Mar, 2010 at 06:38:28pm
Brake fluid will kill all types of paints. On 19th Jan, 2010 wil_h said:
15th Mar, 2010 at 06:58:02pm
2k is miles better, as jason says brake fluid will kill any paint but if you get it off prity quick the 2k should be fine ,pluss its miles more durable.
15th Mar, 2010 at 07:04:01pm
Out of interest Rick, what happens when you put too much hardener in?
15th Mar, 2010 at 07:20:29pm
It will nip up will the shine or even worse craze and look a rite mess, if it nips it can be buffed to help but not whats you want to be doing.
15th Mar, 2010 at 09:33:13pm
i have always used 2k on my cars and wouldnt consider using any other type of paint. |
16th Mar, 2010 at 06:58:21pm
Thanks for all the replys :)
Dave the Cake |
16th Mar, 2010 at 07:02:34pm
ive not used 2k, but heard horror stories about people that have without the proper breathing gear, i wouldnt take the risk tbh
16th Mar, 2010 at 08:37:03pm
On 16th Mar, 2010 Custard said:
I have a twin filtered mask that says its for use with paint spraying. Im only going to use 2k on the bulkhead and ill paint it in my garage doorway, then leg it once finished.... sound safe enough ? i know an airfed mask is the prefered method, but i dont have a second compressor to run one. Dave I use the same compresser for both spraying and my air fed mask. BUT, I have the compressor inlet filter assembly ducted to OUTSIDE my garage if that makes sense. So the compressor doesn't pump back in the cyanides from the 2K. There are a lot of filtered masks on the market that actually have the right charcoal type filter to allow use with 2K anyway, they are just time limited compared to a fresh air fed mask. Schrödinger's cat - so which one am I ??? |
16th Mar, 2010 at 11:36:04pm
problem is im not sure if my compressors man enough to do both! i believe air fed masks need 5 - 8 cfm, trouble is its an old compressor i got of a company that went bust, so i dont really know its spec.... its a 100ltr tank, but only 240v so i doubt its over 10cfm. so i wouldnt have thought it would be enough..
Dave the Cake |
