| Home > For Sale > Pre A+ Rods and Rubber Coupling Drive shafts | |||||||
15th Mar, 2010 at 09:09:54am
A set of 4 pre A+ rods removed from an Austin 1300GT Engine. They still have well used pistons fitted. £20 + post
Edited by apbellamy on 15th Mar, 2010. On 11th Feb, 2015 robert said:
15th Mar, 2010 at 10:40:36am
First dibs on the driveshafts please :) On 26th Oct, 2004 TurboDave16v said:
15th Mar, 2010 at 10:42:55am
No prob's. I want to be 100% certain that my info is correct. Are there any obviouce differences between H.S. and rubber connector ones? I'll put a pic up this evening On 11th Feb, 2015 robert said:
15th Mar, 2010 at 10:49:50am
2nds on drive shafts |
15th Mar, 2010 at 11:07:10am
If HS and rubber X-coupling ones are the same (as Vegard says in another thread) I also have a pair, about to be scrapped.
15th Mar, 2010 at 11:08:00am
To my knowledge, there are two types of Hardy Spicer shafts. The common rubber coupling/ hardy spicer shafts and the Cooper S shafts
15th Mar, 2010 at 11:32:29am
These came from a 71 1275GT. I'll get a pic or two tonight. On 11th Feb, 2015 robert said:
15th Mar, 2010 at 11:40:40am
Early 1071 Cooper S used rubber coupling.
15th Mar, 2010 at 11:49:52am
Andy's sale is first obviously but if there are two of you who want them from Sprocket's description, I'll do mine at the same price.
15th Mar, 2010 at 12:31:37pm
can you get me a pic rod I will take them if they will fit the Coopers type HS type joint,
On 17th Feb, 2009 Rob H said:
15th Mar, 2010 at 01:49:03pm
mine are the type in teh top of this link
15th Mar, 2010 at 03:08:33pm
On 15th Mar, 2010 apbellamy said:
mine are the type in teh top of this link http://www.somerfordmini.co.uk/pdfs/Catalo...riveFlanges.pdf borrowed from another thread... If you look at the part numbers, the rubber and the S are the same. On 13th Jul, 2012 Ben H said:
15th Mar, 2010 at 05:00:32pm
But the Cooper S shafts have that ridge, I know, as I have them on the car. While the others do not, so ergo, they are not the same and Somerford are wrong On 26th Oct, 2004 TurboDave16v said:
15th Mar, 2010 at 06:18:48pm
Pictures:
15th Mar, 2010 at 07:22:39pm
And this is what I have so, after Andy, if they are of use to anyone....
15th Mar, 2010 at 08:53:46pm
Tenner sounds good to me:)
15th Mar, 2010 at 11:30:23pm
Those are fancy schmancy nylon couplings. Don't bin! On 13th Jul, 2012 Ben H said:
15th Mar, 2010 at 11:58:08pm
I dont supose Andy has the other bearing caps for them?
16th Mar, 2010 at 07:26:11am
I think I have the nyclon caps and U bolts in a bucket somewhere. Will look tonight.
16th Mar, 2010 at 07:49:17am
rods, i am interested in just the shafts, can you get a price for pp |
16th Mar, 2010 at 08:11:46am
Phil,
16th Mar, 2010 at 09:09:24am
Phil,
16th Mar, 2010 at 09:26:30am
The cost will be the same for Sprocket. I'm already sending something by this service for somebody else so can easily book a second collection.
21st Mar, 2010 at 10:33:40am
On 16th Mar, 2010 Rod S said:
Phil, Bare shafts are 2.3kg which unfortunately put it into a more expensive price band with Royal Mail, £7.06 for "standard parcels". Earliest I could post would be Saturday. However Parcel2go are currently showing £7.04 for 24-72hr via HDNL and they collect so overall quicker. PM me if you're still interested. pm sent, sorry for the delay in getting back to you |
