| Home > Technical Chat > Help with piston part no. | |||||||
283 Posts Member #: 8215 Senior Member Rayleigh |
17th Mar, 2010 at 12:26:37am
Hello, had these lieing around for quite some time now.
Edited by Custard on 17th Mar, 2010. Dave the Cake |
17th Mar, 2010 at 12:40:26am
Standard Late A+ low compression (9.4:1) piston
Edited by Sprocket on 17th Mar, 2010. On 26th Oct, 2004 TurboDave16v said:
17th Mar, 2010 at 07:36:08am
I was given them in a half built engine. so i measured the bores, cant remember what the measurement was now, but im sure at the time i worked them out as being +20 ...
Dave the Cake |
17th Mar, 2010 at 08:26:56am
is that the same as what nick bud is running ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Mar, 2010 at 09:27:35am
I think Nick has 21253's in his. If something is worth doing, it's worth doing half of. |
17th Mar, 2010 at 09:54:45am
They should have +0.20" on them somewhere if they are +20s.
17th Mar, 2010 at 05:05:42pm
On 17th Mar, 2010 John said:
I think Nick has 21253's in his. yes i think so too john , but i thought there was a piston no. with 6 in it that was the same piston ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Mar, 2010 at 06:00:55pm
21963 is the Cooper A+ high compression piston
17th Mar, 2010 at 06:35:01pm
Right it would appear im a massive fail, they are only standard Size.
Dave the Cake |
17th Mar, 2010 at 11:45:19pm
No the 21962 piston is the same as the 21963 or 21253 pistons, but with a reduced crown hight to give the lower compression. They are good pistons, however, they wont take any more abuse than the 21253s would. It will also depend on the mileage the pistons have been exposed to as to how much they have been stressed, as to how long they would last before they failed, if they failed at all.
18th Mar, 2010 at 05:40:36pm
Thank you Sprocket top man!
Dave the Cake |
18th Mar, 2010 at 06:42:16pm
if it's any reassurance i've done over 30k on my 21253's running 15psi and about 300 running 20psi so far. On 20th Oct, 2015 Tom Fenton said:
18th Mar, 2010 at 08:09:34pm
its hugely reasuring Nick! i hope my engine goes aswell as yours
Dave the Cake |
18th Mar, 2010 at 08:55:10pm
what do you rev that bad boy to nick? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Mar, 2010 at 10:15:53pm
only 6.5k at the minute, i want to give 8k a try to make use of the turbo but i fear i'll need a different cam and a worked bottom end as its all std atm. On 20th Oct, 2015 Tom Fenton said:
