Home > Help Needed / General Tech Chat > NUTS!
Anyone know where to aluminium M7 nuts from?
I thought you'd make them yourself paul? ally hex bar and a m7 tap, job done
As per Jim I'd just make them up myself, out of interest what on earth do you want them for? Also why M7 of all things? surely a courser thread would be better suited to aluminium?
I have no hex bar or M7 tap and I bet they would be more expensive than 2 nuts.
Theyre for a little project Im working on
tap M6 to M7?
jpboost
Member #: 29
Croydon
If you get stuck I've probably got some steel m7s somewhere. They were a right gut to find in steel, so you'll certainly have your work cut out funding them in ally.
I do seem to rember finding Ti ones available.
Too many projects!
need to look at french stuff as i think thats the most common place for m7 to be used.
If you get really stuck I've got some 1/2 aluminium hex but unfortunately I don't have an M7 tap.
Cheers guys, Ill get some 10mm hex and knock some up myself
E30 M3 rocker cover? Only place I know that's using M7 :)
Have you tried tasty nuts? PMSL
http://www.tastynuts.com/Products/Aluminium_nuts_washers
Hmmm on a second look, maybe not! *oh well*
Edited by matty on 20th Mar, 2010.
M7 is used on a few places on 205's, strut top mounts, and holding the distributor to the block to name a couple. Not seen them for sale in alloy though.
worth asking Ric to ask his old chap?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
BBS wheels use M7. Heres a place that does steel and stainless stell ones if you're stuck
http://www.titanium-touch.de/produkte.php?page=mutter
On 30th Apr, 2010 Rod S said:
Gary's description is best
Cheers but they must be aluminium
