Home > General Chat > Fresh air vents in dash
Since I only have MK1's I have no experience of these.
Do you get much fresh cool air from them?
Are they ducted to the front of the car?
Paul
Andy500
Member #: 2443
Cheshire
Yes they are ducted and find them pretty effective, especially if the window is cracked slightly to help with the pressure differentials.
In a daily drive they are very useful.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I rind if I open the rear quarters they work very well.
http://www.twin-turbo.co.uk
evolotion
Member #: 83
Glasgow, Scotland
seconded, keep meening to re-instate mine as the last owner welded the holes shut :(
Denis O'Brien.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Yes Paul - good but ......
The LH passenger side eyeball vent tends to blow warm air into the car as the duct supplying it under the inner wing passes behind the radiator and picks up the warm air blowing out under the wheelarch. Good if you want a side window demister !
The RH drivers side is good as long as the plastic inner wing duct is fitted to scoop the air coming through the grill. If you have removed it in order to fit an intercooler or other kit then the eyeball is not so effective as there's no 'force feed' other than what you get from under the RH inner wing.
I have fitted them to the van as they were not there at all and I just so happened to use the later inner wing repair sections that had the ribbed vertical stiffeners and vent holes. I have a Honda motorbike fan fitted in my inner wing in lieu of the scoop and the drivers air supply is barely noticeable. As I said, only really any good with the scoop fitted IMO but a bit better when the sliding windo is cracked open a smidge.
Richard.
Rick.SPI
Member #: 8027
i have all the kit but never really knew how it worked, i thought the puller cable for the heater just adjusted the water bypass (if thats what its called) on the engine so never inderstood how it decided to take it from the wings.
does any one understand what ive written, if not i can have another attemt *tongue*.
im going to get all my heater and cold air system working in mine now, (going for the do it properly way) so can any1 explain how the cold air blowers work?
Ben H
Member #: 184
No heat ever comes through the fresh air vents, only fresh air. (accepted that it can get warm from passing the radiator)
Rick.SPI
Member #: 8027
i understand that. what i dont get is how it decided to take it from those 2 vents rather than the matrix when the cable only controlls the valve on the engine. or am i confused?
Rick.SPI
Member #: 8027
actually, im confusing myself, im guessing the slider get the cold air vent to work... sorry, through owning a mini for nearly 2 years now and havnt even looked into the heater. this is mainly down to the the cable being snapped so not bothering lol...
durrr
sorry :p
