Home > Technical Chat > Fuel pump blanking plate dimensions
adcyork
Member #: 6807
York
Hi, i don't suppose anyone could measure a fuel pump blanking plate for me could they? I don't have one to take measurements from so any help would be great.
Thanks
Andrew
Edited by adcyork on 21st Mar, 2010.
the_soon_to_be
Member #: 1600
Portsmouth, Hampshire
there about £4 to buy with new gasket, easier option ??
alpa
Member #: 2093
Grenoble, France
What do you need exactly ?
There are I'd say 44.5mm between holes, 2 M8 bolts.
You can remove and place back the pump, there is no paper gasket.
I very much doubt they are M8 bolts on the back of a standard a series block
44mm between holes (so probably actually 1 3/4") 5/16" holes and you could work the other dimensions out by scaling of this photo http://www.minispares.com/Product.aspx?ty=pb&pid=33080
alternativly you could get a gasket and draw round it
Edited by apbellamy on 23rd Mar, 2010.
5/16 UNF
adcyork
Member #: 6807
York
Cheers for the help guys. Good idea on scaling minispares photo rod
