Home > Help Needed / General Tech Chat > Calling those running Emerald M3dK3
Andy500
Member #: 2443
Cheshire
I really want to have a go at the adaptive fueling for my supercharged mpi. Can anybody send me a copy of there AFR map so I can give it a go. Ideally someone with a supercharged engine as per my setup.
Thanks
Andy
a simple L shape is all you really need to get started.
Start with 14.7 top to bottom on the table that covers the idle/ fast idle area, then everything from the the bottom to around 70kpa. Anything in the bit that is outside of this (upper right), put 12.5 to 13 depending on how rich you want to run
You can be clever and smooth it into the rich from the lean, and it will give good results, but needs some time to do.
On the other hand, lol, some one might have done it already *laughing*
Edited by Sprocket on 21st Mar, 2010.
Andy500
Member #: 2443
Cheshire
Thanks sprox, will have a look at this then and give it a try sometime over the coming week or next.
Andy
I've not got my maps on this PC, I can do some screen dumps for you tomorow
Andy500
Member #: 2443
Cheshire
That would be really good thanks Jim
