Home > Help Needed / General Tech Chat > How do I get this out in one piece..?
Si P
Member #: 912
North Yorkshire
Any ideas on getting this out in one piece.
I would like to remove it and re-use it as its nearly new.
I'm fitting my roller drops so it needs to come out.
Si
Some sort of slide hammer?
Don't reuse that. If you remove it, bin it. It's hard to remove it without harming as well, also, it's full of debris.
£8.40
http://www.minispares.com/Product.aspx?ty=...278&title=IDLER NEEDLE ROLLER TYPE ...
Edited by Vegard on 22nd Mar, 2010.
I guess you would have to force out the rollers and then collapse the bearing sections in on themselves. maybe get in carefully with a dremel.
you need a blind/internal puller
or you can drill a few holes behind it and use a punch to remove, then epoxy up the holes or tap and put a grub screw in, theres a thread on here somewhere about just this i think?
does anyone know what happened to dave (danboy) on here, years ago he said he would make me a puller up that can do both transfer bearings, but he seems to have dissapeared off the forum?
oh, forgot, another theory is to fill the hole with grease, them get a piece of wood the same diameter of the idler shaft, and hammer it down hydruallicing (is that a word) the bearing out, but ive never tried that way and dont want to take responsibility for a snapped transfer case
good luck
maccamcvey
Member #: 6673
Worral Sheffield
I watched steve (benross) remove my old one in about 3 min! looked like he had done it a few times lol he drilled 2 holes in from the back, used a small punch to knock it out then taped the holes and put some grub screws in with locktight. genuies!
This is how mine has been done too.
Si P
Member #: 912
North Yorkshire
Cheers Guys
Minispares North have run out of them that’s why I thought I'd ask if you can get them out in a one piece. And they did mention that they would not have any new ones in for quite some time.
Always thought recycling was a bad idea.
Like the Benross Idea. Going to give that a go I think.
Right I'm off into the garage to get the little bastard out.
Si
http://cgi.ebay.co.uk/GEN-Timkin-Torringto...emZ380163946175
I personally use a setup like this:
http://cgi.ebay.co.uk/Brand-New-Clarke-5-P...=item27b02d8253
Nice! :cool:
tadge44
Member #: 2500
Buckinghamshire
Dont try the grease/hydraulicing method or you will get a faceful of grease as it squirts past the needle rollers !
haimesyboi
Member #: 5702
Cornwall
You can try putting the casing in the oven, putting face down on the floor and tapping the back with a soft hammer, and if your lucky it might fall out.
Voice of experience?
haimesyboi
Member #: 5702
Cornwall
Ive had success with motorbike casings using this method.
But my idler bearing had been sat for a long time and i had to use a blind puller.
tadge44
Member #: 2500
Buckinghamshire
The grease/hydraulic method only works when it is a blind bush and you have a close fitting drift. On anything else the pressure takes the easy way out, usually up your nose and down your shirt.
You could try it the Guessworks way. Heat the area at the back of the bearing with a blow torch then twat the casing edge on a block of wood until it falls out.
Perhaps this may be why certain gearboxes unexplainedly leak?
nibble36
Member #: 4273
stoke on trent
pop it in the oven on hi and give it 20 mins keep eye on it and it will fall out i did one the other week
is it wise to get long thin bits of ally that hot though?
has anyone checked them for straightness after?
may not affect them, but worth checking i guess?
best_stig
Member #: 6449
Brisbane, Australia
Id want to check them.
May have fooked it completely. Different metals in the bearing expand at different rates, so may break each other as they expand.
In boost we trust
just spotted this, quite a good rang and cheap too
http://cgi.ebay.co.uk/Pilot-Spigot-Bearing...=item48374458ed
