| Home > Help Needed / General Tech Chat > coating | |||||||
22nd Jan, 2005 at 12:25:54am
had a little root around in the garage earlier to try and find some bits for alex and i found a manifold i did not think i had Crystal Sound Audio said:
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
22nd Jan, 2005 at 12:58:42am
Wolfie, there are ceramic coatings out there that will stand up to the heat. The only way to do it correctly is to have it done inside and out. This will have the added benefit of keeping the exhaust gases hot, thus more power through the turbo (larger differential from the high-pressure exhaust side to the lower pressure side), and will help with flow even on a NA engine (the hotter gases help pull the charge out of the chamber is what I understand).
Site Admin 6302 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
22nd Jan, 2005 at 01:03:45am
Sounds like an interesting experiment! |
22nd Jan, 2005 at 01:05:38am
My friend says he's used it, and had great results. Prep is exteremly important in these things, though! **************************************
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
22nd Jan, 2005 at 10:42:19am
I've never seen a good diy ceramic coating, whats it called? any detail?
