Home > Help Needed / General Tech Chat > help.manifold gasket leak after hard driving
jom
Member #: 6003
i have changed 3 times gasket whithin 3 weeks. its really good when every time i just fit a new one, no leak. But after hard accelerate, the gasket on center exhaust port just blow off, and stat to leak.*frown*
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Take your manifolds off to check if the surfaces are flat. If not file them
On 30th Apr, 2010 Rod S said:
Gary's description is best
jom
Member #: 6003
i will have look tomorrow..and i have tried put second gasket at middle, but still blow off after a week
GaryOS
Member #: 2810
Dublin, Ireland
Thats just a bodge to be honest. Are the inlet and exhaust flanges the same thickness?
jom
Member #: 6003
no, not same thickness. but i made half side of the washer a bit thiner to fit it
What gasket are you using?
jom
Member #: 6003
the normal one before.but last time i put a turbo gasket on it , there are metal ring on it.. but i found the gap at middle is too big ,so i scissor this part from normal gasket ,and fit with the turbo gasket..but now the middle part is blowd off, but the turbo gasket is still good
Well in my experience the turbo gaskets are unbustable (if that's a word).
So as suggested above you have a problem with your flange (f'nar f'nar). I suspect that your manifold is distorted.
Either get it ground flat, or get another one that is flat. No other option I'm afraid.
Mr Joshua
Member #: 1954
Luton Bedfordshire
The Original turbo gasket was metal on both faces and until last summer was like hens teeth to find.
Never had an issue with one of the above.
Own the day
Star Mag
Member #: 375
Leicestershire
You want the one from minispares with the metal inserts on the exhaust ports! these give no problems with good head and manifold faces. Ron
