Home > Technical Chat > Pros and cons of turboing through these
Mr Joshua
Member #: 1954
Luton Bedfordshire
I was planning on a suck through setup using my Weber 45 but have decided not to bother as I have leaned towards utilising these.
What do you think will be the pros and cons of turbing through these twin 38s?
Edited by Mr Joshua on 29th Mar, 2010.
Own the day
con's difficut to seal with those dashpots, dificult to set up, need to make a plenum, will not fit with metro turbo exhaust manifold.
pro's ....erm.....
suck through so no need to seal?
even if there were any pro's, wtf bother when a single carb will do and is simpler?
evolotion
Member #: 83
Glasgow, Scotland
suck through twin carbs?!
Denis O'Brien.
why not triple carbs whilst were at it then?
Pro's - none
Con's - extra weight, complexity, harder to fit.
AWDmoke
Member #: 713
Western Australia
Pro - better throttle response IF blow through
Cons - difficult to seal, more complex, extra weight, need to cut bulkhead.
On 24th Dec, 2008 Nic said:
what power is matts mini running on a single hif?
Mr Joshua
Member #: 1954
Luton Bedfordshire
Sorry chaps. I should have corrected my first post I was leaning away from the suck through webber setup and thinking of the more traditional Metro blow through setup.
Own the day
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
pros: nonl
cause : they'll be a lot better if fitted to my historic 1275 n/a gt...
would you sale them *happy* ?
Mr Joshua
Member #: 1954
Luton Bedfordshire
I would have to buy them first *hehe!*
Own the day
if your doing twin carbs why not just go for two hiff 44's and prove people wrong? why not try somthing new today *wink*
Mr Joshua
Member #: 1954
Luton Bedfordshire
Well I was offered these and was liking the thought of faster flow through the smaller throats to aid better low down pull, where the 44s may be a little sluggish
Own the day
I'd like to see a Twin HIF38 turbo.
