| Home > Help Needed / General Tech Chat > Adjusting Castor | |||||||
6th Apr, 2010 at 01:36:12pm
Got outbid by 50p on some turnplates again last night :(
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
6th Apr, 2010 at 01:54:24pm
i think you'd have to have the whole car lifted level to begin with - front and back, and make sure the axle stands are under the arms so the cars weight is compressing the suspension as if it were on the ground. |
6th Apr, 2010 at 02:06:41pm
Obviously the tyres dragging on the floor will influence the accuracy, but you can measure it with pretty reasonable success with the car on the floor. I do it with a spirit level and some trigonometry in any case, so the accuracy I achieve probably isn't good enough to warrant buying turn plates.
6th Apr, 2010 at 02:16:04pm
ive been doing it the same way tom, just chalking the angles on the garage floor, measuring, adjusting, wheeling it back and forth and re-checking, but its quite inconsistent and time consuming to get spot on
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
6th Apr, 2010 at 03:15:23pm
I was once pointed in the direction of 2nd hand throw out bearings for DIY turnplates Edited by Asphalt on 6th Apr, 2010. [X] nail here for new monitor |
6th Apr, 2010 at 03:46:33pm
I have turn tables, but often find it quicker to have some ally box section, cut and welded at 20 degrees, run this down the sill and against the wheel, turn the wheel and till it's at paralell, or for camber gain the good old cross on the floor Team www.sheepspeed.com Racing
