| Home > Help Needed / General Tech Chat > Hardy Spicer Output Flange Large Bolt and washer Dimensions | |||||||
7th Apr, 2010 at 09:21:32pm
Can any one help. I am looking for the dimensions of the large shoulder bolt and washer that retains the hardy spicer output flange onto the diff output shaft. I am primadally after the length of the threaded portion, and, the length and diameter of the shoulder under the head of the bolt. Also the OD, ID and thickness of the big washer.
7th Apr, 2010 at 09:53:28pm
iv'e just taken a nut and washer off a box i have , the nut is the same as the rear hub retainer, IE 5/8unf slot nut, and the washer looks similar and is 1.250" OD 0.650" ID and 0.125"" thick,
Edited by fastcarl on 7th Apr, 2010. |
7th Apr, 2010 at 10:25:34pm
Carl, the Hardy spicer is a bolt, the nuts are for the rubber yokes.
7th Apr, 2010 at 10:37:21pm
7th Apr, 2010 at 10:38:56pm
Oh, and to add, the rubber yoke output SHAFT is of a similar design to the pot joint shaft in that it narrows after the splines and before the bush journal, where as, the hardy spicer shaft is has the same girth along its length On 26th Oct, 2004 TurboDave16v said:
7th Apr, 2010 at 10:43:09pm
On 7th Apr, 2010 fastcarl said:
the Hardy spicer is a bolt, the nuts are for the rubber yokes. youv'e lost me now, carl The old rubber couplings used a castle nut and big washer per side to retain the output 'flange (yoke)' onto the output shaft (the bit in the diff with the beval gear on the end) The hardy spicer output flange is retained by a large special shouldered bolt, spring washer, big flat washer, rubber seal and two collets per side. http://www.somerfordmini.co.uk/pdfs/Catalo...ifferential.pdf On 26th Oct, 2004 TurboDave16v said:
7th Apr, 2010 at 10:53:33pm
so you're using the auto hady spicer outputs, sorry can't help.
7th Apr, 2010 at 11:12:00pm
so you're using the auto hady spicer outputs, sorry can't help. carl Cooper S
![]() 31 Posts Member #: 1961 Member Wellington New Zealand |
8th Apr, 2010 at 11:28:58am
Could try minisport in AUS
Edited by NealfromNZ on 8th Apr, 2010. |
10th Apr, 2010 at 05:29:29am
Sorry Sprocket ,
10th Apr, 2010 at 09:11:17am
On 10th Apr, 2010 NealfromNZ said:
Sorry Sprocket , I don't has a 1inch socket to take the bugger out. I'll get one over the next week. Can anyone else help ? Thanks buddy I would have thought Vegard might have been able to help, but I have not seen him about recently On 26th Oct, 2004 TurboDave16v said:
12th Apr, 2010 at 07:14:16am
my sets are on the car, so I can not help, sorry.
12th Apr, 2010 at 11:31:12am
I'm afraid all of the ones I've got are hidden between HS joints.
Edited by Vegard on 12th Apr, 2010. On 13th Jul, 2012 Ben H said:
13th Apr, 2010 at 03:09:52pm
Vegard, the part number in that link for the bolt relates to the seal and NOT the bolt, so either the description is wrong or the part number is. I will phone them, but I reckon its going to be the right part number and the wrong description, considering no one anywhere actualy lists the bolts other than Somerfords. On 26th Oct, 2004 TurboDave16v said:
13th Apr, 2010 at 04:32:47pm
The description says it is the seal (for the output bolt). |
13th Apr, 2010 at 05:17:55pm
lol thats the human brain for you, for what ever reason, I never read that bit On 26th Oct, 2004 TurboDave16v said:
72 Posts Member #: 6792 Advanced Member |
30th Apr, 2010 at 11:30:56pm
Are these the parts you need measured?
