Home > Help Needed / General Tech Chat > NA 1293 - is it possible to change to turbo and whats needed
hundred
Member #: 8836
Hi, I have been offered a freshly rebuilt NA 1293 but ideally I want to go turbo in the future, is this possible and if so what would I need in order to do the change.
Unfortunately I don't know the exact spec of the engine.
Any help appreciated
cheers Graham
without wanting to sound like a cunt...
have a read in the beginners section you bloody beginner!
Ha, really you need to know the spec of the engine before anything else.
hundred
Member #: 8836
thanks for the advice, really helpful
Mr Hundred
The best thing to do is have a read, there is lots of information out there.
Then come back with specific questions. Nobody will be able to help you unless you can tell us what pistons you are using, what head you have, how much power you want etc etc
Also, try and ignoire the people being tw@s. We're all hear to help, but only if you show that you are willing to try and help yourself first.
rosco454
Member #: 5222
Northumberland
Have a read of this
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4724
& this
http://www.turbo-mini.com/67709.html
Both links cover turbo/na differences etc.As other people have said you need to put up your current spec as that dictates what components you will need to change,same for how much power and boost you want to run as again that will determine which of your current components are suitable to be re-used.
Cheers Ross.
hundred
Member #: 8836
thanks for the replies, i had looked at these links previously but as these dealt with a 1275 and the engine that i have been offered is a 1293 i thought i had better ask.
as regards the engine i know very little about it other than it has been refurbed, it is listed on ebay item number 140392398448, does this look decent value for money?
I am also about as much of a newbie to engine building as you can get so forgive me if i dont quite know what all the terminology is.
My intention is to finish my project (full rebuild, respray, etc) and fit the standard 998 and build the turbo to fit at a later date.
cheers graham
sorry to be so blunt, but if you dont know what you have, how can anyone advise you if its ok to use on a turbo engine or not?
try asking the engine builder/reconditioner what components/spec the engine is. that will give you a starting point, but to be brutally honest, theres really nothing that you can ask that hasnt been before, so do a search and come back with specific questions and people will help.
so far, this is an entirely pointless thread
That ebay ad tells you fubar all about whats in the engine so you have no chance of getting the info you are after from here!
As for value for money who knows! It could be an all singing all dancing engine or a piece of shite.
rosco454
Member #: 5222
Northumberland
Re - Value for money?
If i was looking for an n/a engine then i would want to see some proof of spec on what i was getting for my £800.(It could well be a standard untouched 1275 for all we know).
If i was buying to go turbo then personally i wouldnt go for it,especially without a spec as you could well end up spending as much on it as you would starting with any standard 1275.
Cheers Ross.
Edited by rosco454 on 9th Apr, 2010.
That is the wrong useage of the acronym FUBAR. Just say what we all know you were tinking at the time *hehe!*
http://en.wikipedia.org/wiki/FUBAR *wink*
on a side note, I found my new best phrase, but as of yet I have not worked out how to work it into conversation *hehe!*
Frangible nuts *hehe!*
http://en.wikipedia.org/wiki/Frangible_nut
Your name states the number of times this question has been asked. As you can see from the above comments.
Echo above!
Mike :)
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have used frangible many time in my life. Frangible triggers are the glass bulbs you get in sprinkler head. When they get hot in a fire they break and the sprinkler sprinkles.
http://www.twin-turbo.co.uk
