Home > Help Needed / General Tech Chat > Gearbox casing cracks and ARP rod bolts
Hello.
Firstly is this a common place to crack a gearbox casing? I dont think its a casting mark, but I could be wrong. Its on the top of the diff housing
And
Are these ARP rod bolts, I think I may have been mistaken. They are 6 years old if that makes any difference to design changes.
Much obliged
PaulH
Member #: 2340
Dublin Ireland
The bolts look like the uprated Mini Spares rod bolt there defently not ARP
And that does look like a crack in the casing Auto Test gearbox crack here all the time.
On 17th Feb, 2009 Rob H said:
Thanks
That explains this then:
I may have slightly over tightened them
Its not a good weekend for building engines
better to kind out now eh,
ARP ones are black arn't they?
Fuck me Nic, I would have thought you would have stress relieved the gear case, or is that not one of yours :)
ARP bolts use a 6 sided nut, are black and have a far better finish on them, I dont recall them being knurled just under the head either.
Edited by Sprocket on 9th Apr, 2010.
Ill get some arp ones ordered, these have been holding up 7500rpm well though
The case was std, i was going to use another, got it on the bench to give it some work and spotted a horrible casting mark, picked up this one to go back to it and then spotted the crack.
Damn the slicks!!! They have cost me a fortune in repairs
Star Mag
Member #: 375
Leicestershire
The slicks cost me alot of money as well Nic! Flywheel, backplate and clutch plate. I'm glad the clutch slipped and saved the box.
Your casing definatly looks cracked.
thats the problem with cracks, theyre terribly moreish
They are definitely not ARPs.
and i think it is not a crack but a casting joint,
All ARP bolts say ARP *wink*
If they have a small "Knob" on top of them, they are the uprated Minispares ones that now are discontinued.
