| Home > General Chat > Dzus fasteners | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
24th Jan, 2005 at 08:04:22pm
had a good google around but cant find an online retailer of panel fasteners, where do u get yours from?
24th Jan, 2005 at 09:00:54pm
Do a search for Dzus
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
24th Jan, 2005 at 09:48:59pm
I cant get them to stay in i have lost a couple through them fallin out!! I think a lot of racers cover them with tape.
25th Jan, 2005 at 07:36:32am
Mine always stayed in, maybe you've not got the ones for the right panel thickness so they're a bit loose?
25th Jan, 2005 at 09:28:56am
ah merlin motorsport do them, based at castle coombe. hm, what thickness wil li need? I'll be doing the usual 'through the wing and through a plate behind' design.
25th Jan, 2005 at 10:11:22am
The thickness of a wing and the plate you make then |
25th Jan, 2005 at 11:17:44am
Pot-dans kept fallinh out too, i just found some on minispeeds website :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
25th Jan, 2005 at 11:26:58am
Dzus are fairly fiddly to set up properly, as iain said you also need to make sure you have the correct depth size and they line up well.
25th Jan, 2005 at 11:30:43am
is there another recommended method? i'd like to keep it as steath as poss, i've just been looking at camloks, they look pretty similar to dzus.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
26th Jan, 2005 at 09:57:11am
Dzus fasteners are not that great. If you get any side loaading on them it wears the cup under the head and they will then fall out completely. The Mounting springs tend to give up the ghoast as well after a bit. When you install them you want them so they are just nice and snugg under some sring tension from the mounting spring. I dont think that you will get great life from them on mounting front ends, but as they are not that expensive you can afford to replace them from time to time.
