Home > General Chat > dump valve
nibble36
Member #: 4273
stoke on trent
hi all after putting my new shinny turbo back on the car seen to have a bit more lag than be for so had a look at it to day and looked at dump valve as it was realy slow in opening and closeing
so took it bits to give it a clean as it seemed to be sticking and when got it in bits the o ring seal had some how got 2 big mmmm couldent get it back ,is this common and can you get bits for bailey dump valves is there a better seal than a rubber o ring
any help pls thanks nibble
turbominivanman
Member #: 1504
Westbury, Wiltshire
Neil.
Take a look at my earlier post with the same issue.
It's a problem with fuel contamination of the O seal which swells it and makes the piston lazy.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=353272
Managed to overcome the swelling of the original on mine by fitting a smaller diameter O ring with a lower core thickness and smearing the piston and bore in a 'little' Petroleum Jelly (Vaseline).
Has sorted mine.
I've seen piston and diaphragm DV repair kits on the Forge website so there must be something on the Bailey website I assume.
Richard.
Edited by turbominivanman on 11th Apr, 2010.
Go to your local hydraulics supplier and buy a "viton" o-ring of the correct size. This will be un affected by the fuel, job sorted.
nibble36
Member #: 4273
stoke on trent
nice one guys im off shopping tomorrow lol
