| Home > Help Needed / General Tech Chat > Skim 1275 cylinder head | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
12th Apr, 2010 at 10:19:41am
Does anybody know how much a standard 12g940 can be skimmed? and how much thou for each cc removed?
Class C 3rd Place Avon 2011 14.18 @101mph |
12th Apr, 2010 at 10:24:56am
what pistons does it have in?
Yes i moved to the darkside |
12th Apr, 2010 at 10:49:17am
It as +40 10cc cast Omegas pistons, 6.8cc decked height above the pistons (already been decked 0.040), due to short stroke crank, s rods etc.. The simple thing to do is deck the block a further 0.060", but that means taking out and striping the engine. Really want to go to L2B and still got to MOT, Rolling Road etc.
Edited by alaskanow0 on 12th Apr, 2010. Class C 3rd Place Avon 2011 14.18 @101mph |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
12th Apr, 2010 at 11:19:49am
I would suggest measuring the depth of the oil passage in the head and subtracting it from the total thickness of the head. The resulting distance can be reduced to no less than 0.080 in (according to the yellow bible)
12th Apr, 2010 at 11:25:28am
I've done 15cc..
12th Apr, 2010 at 11:31:38am
mine is less Vegard, its 14cc |
12th Apr, 2010 at 12:02:14pm
And then it'll look something like this:
12th Apr, 2010 at 12:24:34pm
Are you proud of that picture Vegard? On 26th Oct, 2004 TurboDave16v said:
12th Apr, 2010 at 01:17:43pm
Ok, I used a piece of graph paper and pencil trace the chamber size, works out at 31cc surface area, therefore 31cm x 2mm (0.080) = 6.22cc taken from the standard 21.4cc giving me a 15.18cc. I cant find my yellow book, but found another Vizard book, how do you measure down the oil hole on a 12g940 as its not straight? Where else can you measure? Edited by alaskanow0 on 12th Apr, 2010. Class C 3rd Place Avon 2011 14.18 @101mph |
12th Apr, 2010 at 01:39:51pm
On 12th Apr, 2010 alaskanow0 said:
Ok, I used a piece of graph paper and pencil trace the chamber size, works out at 31cc surface area, therefore 31cm x 2mm (0.080) = 6.22cc giving me a 15.18cc. I cant find my yellow book, but found another Vizard book, how do you measure down the oil hole on a 12g940 as its not straight? Where else can you measure? You measure the the combustion chamber with a burette, and stop this bloody guesswork
On 12th Apr, 2010 Sprocket said:
Some one slipped with the die grinder though Not someone, I did
its probibly the one you post the most.
