Home > Help Needed / General Tech Chat > Do you need a speedo/fuel gauge for a MOT?
jonb_5
Member #: 3193
Torbay, Devon
Hi
As the title really - Do you need a speedo/fuel gauge for a MOT?
I am getting the mini rolling roaded and MOT'd and wanted to find out if i need to sort the speedo before its goes in.
I have a speedo where the working one will be, so indicators lights, full beam etc will all be in place. The speedo just wont work.
Jon
I think so long as its there i think youll be fine.
You should be fine, as long as its there it shouldnt be a problem.
Mine has never worked properly and its been fine for the past god knows how many years
just stick a satnav in lol
Nick
Member #: 154
Midlands
i haven't even had one fitted for the last 3 MOT's
have a look here, iirc you dont need one, i have in my head you dont anyway as i wasnt going to fit mine (edit: speedo)
http://www.motinfo.gov.uk/htdocs/index.htm
Edited by Brett on 12th Apr, 2010.
Whilst a speedo isn't an explicit MoT requirement you are legally required to have some means of determining the speed of your vehicle and the MoT tester may not be happy passing a car that isn't road legal.
That said the law is very vague as to the accuracy of speedo, also the MoT tester is not required to drive the car at any stage of an MoT and I don't think they're allowed to take it for a test ride (although I might be wrong) so it is questionable how they can prove it works correctly.
Fuel gauge doesn't matter.
Edited by Rob H on 13th Apr, 2010.
Its weird really...
Here in NI not only must you have a working speedo...but it must have both mph and kph available.
Lots of the import guys get caught out as they just convert their kph speedo's to mph with convertors.
There have been literally hundreds of MOT failures for that alone.
Although the addition of a Sat Nav for speed display is an interesting one...although I'm sure you would have to fight hard to get it passed that way !
pot_dan
Member #: 326
bradford, west yorks
ditto :)
fuel gauge hasent worked in the 5 years i have owned it either..
i do plan on fitting a speedo cable before the next mot tho..
RAC cant beleive i have broke down so many times and done no miles*tongue*
http://turbominis.co.uk/car/105/
Carl
Member #: 95
liverpool-on-sea
the law and mot are 2 very different things for some strange reason, which is mainly to do with money. there are lots of things which are illegal but the mot man cant fail them.
the tester can test drive the car if they think they need to on an mot
if you leave the milage blank it just prints "milage not displayed" on the mot, so dont worry about your speedo
