Home > Help Needed / General Tech Chat > oil and water circulation
whats the hot and cold sids of the oil and water? i mean if you have an oil cooler fitted is the hot side on the block or the oil filter housing, and the water is the hot side the thermostat housing side or the waterpump side?
Hot side for water is the thermostat housing as water comes out of cyl head.
Hot side for oil I think is the block side.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
you have the oil cooler post oil filter before the block...
only place you can!
alex
AlexF
