| Home > Technical Chat > Fuel Pressure Problems. | |||||||
![]() 300 Posts Member #: 1746 Senior Member Kent |
14th Apr, 2010 at 06:35:31pm
Well i went to set up my fuel pressure today, fitted the pressure gauge inline with the output of the regulator and put the pump on, the gauge was only showing about 1 bar.
14th Apr, 2010 at 06:40:50pm
Are you using a carb'd car with a metro turbo regulator and an EFI pump? If so, your target fuel pressure at idle is between 3 and 5 psi. (14.5psi equals 1 Bar, or something close to that). The boost take-off takes care of the fuel pressure rise and maintains fuel pressure at the set value above boost pressure. i.e. if you set pressure to 4 psi and run 10psi boost, fuel pressure at that time will be 14psi (10+4) On 12th Nov, 2009 Paul S said:
Gary's description is best |
14th Apr, 2010 at 06:54:07pm
Are you sure you are reading pressure in bar ???
Edited by Rod S on 14th Apr, 2010. Schrödinger's cat - so which one am I ??? |
14th Apr, 2010 at 09:26:59pm
Dam looks like iv cocked that up haha, yes i was reading in bar, so am i looking to set the pressure at 3-4psi not bar?
14th Apr, 2010 at 09:28:57pm
14th Apr, 2010 at 10:03:31pm
Perfect, alot lower pressure than i was thinking then haha. I did get i bit concerned when fuel spurted out the plenum take off.
15th Apr, 2010 at 10:42:43am
when you have set the pressure to the 3-5psi, when you are driving its handy to be able to see the gauge whilst boosting to see if it goes up properly, as gary said if you set to 4psi at idle and your running 10psi of boost then when your driving and its at 10psi of boost your fuel pressure gauge should be reading 14psi |
15th Apr, 2010 at 08:15:26pm
And now that you have basically filled your entire intake system with fuel...time to strip it all down to clean out, including removal of any fuel dumped into the cylinders, and possibly also past the rings and into the sump. 9.85 @ 145mph
15th Apr, 2010 at 09:49:10pm
On 15th Apr, 2010 stevieturbo said:
And now that you have basically filled your entire intake system with fuel...time to strip it all down to clean out, including removal of any fuel dumped into the cylinders, and possibly also past the rings and into the sump. could it also have possibly blown the seal in the bottom of the carb? |
16th Apr, 2010 at 09:12:56pm
What seal ? 9.85 @ 145mph
16th Apr, 2010 at 09:23:01pm
Iv had another go with the regulator today, but it only seems to show any pressure on the gauge when the middle bolt is near enough completely in, is this normal? as it doesnt look like there is enough in the thread to fit the lock nut...
16th Apr, 2010 at 10:02:33pm
The diaphragm could be wanked after seeing such high pressure On 12th Nov, 2009 Paul S said:
17th Apr, 2010 at 12:35:58am
I dont think thats happened, but its a possibility.
17th Apr, 2010 at 03:14:47am
Well i think iv now found my problem, after spending ages searching on google i came accross this image:
17th Apr, 2010 at 09:29:37am
Just openned one up.....
Edited by Rod S on 17th Apr, 2010. Schrödinger's cat - so which one am I ??? |
18th Apr, 2010 at 04:30:53pm
Thanks for having a look at one for me. Iv just had a look at mine, and did a quick test with a 5 pence coin as it seemed to be near enough the same diameter as the locating disk on the diaphragm.
