Home > General Chat > ignitian management
dale_hick
Member #: 7964
wakefield
hi all.........quite new to the mini turbo game and i have a look around, so he go's i want to ditch the dizzy it seems nearly everybody has a megajolt on here but has anybody rrunning anything different and what results have you had and any plus and negatives? i'm looking possibly towards the msd ignitian parts any advice cheers dale
Msd not worth it IMO I looked into it ran the car on the dizzy first then switched to mj
Edited by gr4h4m on 18th Apr, 2010.
MegaJolt is cheap, straightforward, and does all that a turbo A series reasonably requires of it. This is why lots of people on here use it.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Or Megasquirt as it does ignition and injection if you ever need to run Efi one day.
But TBH, MJ is a good start IMO and is good value plus maps are readily available and easy to change yerself with readily available software and downloads.
There's lots of choice.
Richard.
As Richard says, you might want to consider MegaSquirt.
It does everything MegJolt does for ignition and can do things like boost control without even considering it's future potential for fuel injection.
A Megasquirt module built just for ignition has the advantage that it doesn't need the EDIS module, it can be built to drive the coilpack directly.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I concur MJ is all you would want from an ignition system, but if you spend a few extra pounds on MS it does a lot more. Not just potentially more control, but you can monitor and log much more so it makes setting up the car potentially better.
http://www.twin-turbo.co.uk
turbominivanman
Member #: 1504
Westbury, Wiltshire
As Rod says.
I run my MS1 Extra to operate wasted spark direct coil pack ignition only but I also control my fuel pump with it, my lecky fan, my water injection pump and water injection nozzle and it drives my tacho, gives me full data logging capability and takes the input from my AEM WB O2 sensor. All with standard Rover SPi air and coolant sensors.
Without doubt, the fitting of mappable ignition and a wideband O2 have been the two BEST mods I've done.
When I bought my MS ECU from Phil Ringwood in 2006 (www.ExtraEFi.co.uk) it was £270 and was one of the first to have 5 outputs. I think the same MS1 unit now is about £350 and if you were to drop the water injection control you could easily do boost control as Rod says.
If I want to fit injection, it's a simple case of joining up the current unused wires from the ECU to the Idle valve and injectors and Bob's your mothers brother.
Go on, you know you want to ......... *happy*
Richard.
