Home > General Chat > roller cam followers
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
What are the advantages of a roller cam follower over the traditional flat tappet follower ?
The benefits are described on most of the suppliers websites. For instance...
http://www.minispares.com/Product.aspx?pid=37972
http://www.minisport.com/mini-spare-parts/..._MSLMS0483.html
One of you is misunderstood..Do you mean roller rockers or roller cam
well, wear is obviously going to be a factor, along with friction/resistance (i.e.powerloss), also i believe roller followers allow ramp angles that normal cams cannot give
aaaaaaages ago a lad on here who's name i darent mention for fear of legal action (mini1071s) was going on and on, and on and on and on about these, whether he managed to convert a mini series block to take roller followers or not well never know as he was full of wild claims and never substantiated any of them
have a search though, alot of what he said seemed to stack up
Oh dear, it's been a long day.
Sorry, you said roller follower. Have a chat with mini13 Joe. He's been banging on about messing with these for an eternity.
JoeYbaby has pretty much summed it up.
Wtf is roller follower? A follower with a roller bearing some how fitted in the top??
http://images.google.co.uk/imgres?imgurl=h...%26tbs%3Disch:1
EDIT: I think that they're used on high powered V8s in the US.
Edited by Rob H on 21st Apr, 2010.
Oooh very interesting!
I'm sure there must be someone on this forum with the skills to make this happen *smiley*
01smartc
Member #: 2563
Tamworth
The hardest bit to make happen is a keyway...
The roller follower cannot be allowed to rotate as normal cus the roller will point the wrong way :) So a keyway down the follower hole is required.. not so easy to machine
Chris
will the follower rotate in its seat? As in spin around so the roller bearing is pointing the outwards
yes, you have to consider the time that it spends not in contact with the cam ie the base circle.
Base circle is good way of putting it. Wonder if anyones tried it?
Alex
Member #: 1851
Woolavington, Zummerzet
I have had a long hard think about these in the past, after seeing them in the obligatory copy of Hot Rod magazine when over in the US.
Some of the ones I've seen seem to come in pairs, with a sliding tiebar between them to stop the spinning and keep them in the same axis. I reckoned that it would be relatively simple to fit them in a 998 or S block, where the tappet chests would allow easy access.
Having said that, you can't run them on a normal cam - the profiles are wrong for the rollers... so you'd then have to develop an A-series roller cam.
roller cams have been done in the A, but only in the blocks with tappet chests as mentioned,
also as mentioned you would need a custom grind for a few reasons, first off you want a rounded lobe, and different tappet ramp shape, also the lobe needs to be flat, I belive A series ones are ever so slightly skewed to make the follower rotate,
also flat tapet cams actually lift faster than a roller cam can at low lifts, so you need to really get the profile lifting ( and dwelling at full lift) to utelize the flow of the head.
I have looked at many sets of followers to see if they could be made to go into the non tappet chest block, about the best bet are jesel solid keyed followers, these can be picked up from nascars with test mileage on them, but are only availabel in .937" diameter which may be too big to fit,
another posibility is the lifter from the ford/mazda 4.0 V6, it is .86 diameter, but is heavy and has hudraulic gubbins in which you would want to lose.
Alex
Member #: 1851
Another thing I've pondered is whether it would be possible to build a cam follower that looked like the end of a biro - a cylinder with a captive but free moving ball bearing in the bottom.
It would alleviate the spinning problem and allow them to be fitted to any block, but I suspect that the forces involved would destroy cam and follower in short order, or at best leave a groove in the cam...
Asphalt
Member #: 1027
Germini, black forrest
How about a kewayed follower & a pin trough the block to prevent it spinning?
[X] nail here for new monitor
yes but you have to get the hole through the block in the right place, plus you then have to put a groove into a hardened follower.
doesnt sound so hard ..
says the mad scientist!
How long before roberts nocked this up?
Advantage
Member #: 1450
Near Paris - France
And you still have the profile of the camshaft issue ...
Even in a "cost no object" project, it would sound like hair splitting, especially in a turbo mini ...
My crazy thoughts of a few weksbacks was to use two A series camshaft in overhead design for a X flow 16 valves head.
Could work for 8 valves thought ...
Rusty by nature
Sam
Member #: 1686
Oxford
I give it a week.
OMG Robert that's a big one
Advantage
Member #: 1450
Near Paris - France
I give it a decade before it's built ...
Rusty by nature
