Home > Help Needed / General Tech Chat > T2 to T3 adapters ?????
Dangerous
Member #: 417
Being unable to get hold of one
has anyone got any pics??????
The stud alignment on mine is such that the whole t2 "oblong" nearly fits inside the t3 studs,so is it just lose the corners off the turbo so its like slotted.
If I make a 10mm thick plate then Id of thought I would be tapping and studding sort of offset into the(countersunk or counterbored) bolts that hold the plate to the t3 manifold.Unless u mount to one side???
And if u plate to the t2 first .......well that won't work either
Or do you plate to the manifold with new holes drilled and tapped to not interfere with where u want the t2 holes(thats the only way I see)*oh well*
May b missing somethink here
Brian
akirch
Member #: 399
Austria
pictures, like this?
http://www.minifreunde.at
still not got mine :(
pete
Member #: 275
bonie scotland
jimster were have all the t2 plates gone//////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// postman jock no delivered mine yet
clubman_dan
Member #: 142
Winchester
or mine?
Jimster,
You're a turd.
These guys need the plates!
D
http://www.netsnapshot.com/pcw/buildalbum-...=2&ACCOUNT=4541
Yer come on Jim.
sorry guys, I collected the plates tonight from the workshop, to save me time, can you pm your addresses
Kean
Member #: 341
aka T2clubby
South Staffs
Yeh Jimster I need my s/c drops!!
you have pm, gears and 6 plates in my car, pm me your address's and I'll post lunch time
clubman_dan
Member #: 142
Winchester
you get my pm jim??
