| Home > Technical Chat > MAP sensors - any recommendations? | |||||||
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
21st Apr, 2010 at 05:18:08pm
I'm slowly but surely making some progress with my Supercharged MPI.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
21st Apr, 2010 at 05:20:43pm
Marelli ones are pretty standard and work OK. Can be bought cheaper than Emerald. Also work out what your max boost is and buy one to suit, the 1 bar ones are much cheaper (standard Sierra Cosworth)
21st Apr, 2010 at 06:15:54pm
i have the 3 bar cossie one
21st Apr, 2010 at 07:29:53pm
Ive never had problems with any of them. And £50 new isnt expensive in anyones book. 9.85 @ 145mph
21st Apr, 2010 at 07:38:31pm
Coolio - I'm gonna see what prices the local autofactors come up with.
21st Apr, 2010 at 08:07:02pm
local motorfactors will likely be dear. Some sensors could be found second hand for little money.
21st Apr, 2010 at 10:03:46pm
I'm looking at running no more than 0.6 bar.
21st Apr, 2010 at 10:07:30pm
Other than it being a waste of money. See post above.
21st Apr, 2010 at 10:08:23pm
ta da
21st Apr, 2010 at 10:14:48pm
On 21st Apr, 2010 Tom Fenton said:
Other than it being a waste of money. See post above. Fair point..... On 21st Apr, 2010 Tom Fenton said:
ta da http://cgi.ebay.co.uk/Genuine-ford-coswort...=item2c541c84d8 Braw.
Edited by MrOz on 21st Apr, 2010. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
21st Apr, 2010 at 11:06:24pm
Ahh..but how much is he looking for postage ?? lol
21st Apr, 2010 at 11:16:09pm
On 21st Apr, 2010 stevieturbo said:
Ahh..but how much is he looking for postage ?? lol I think Ive a Marelli 2.5bar one here too. Or pretty much any turbocharged car will have one that will do. Be it Cossie, Subaru, etc Don't suppose you're looking to sell it...... "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
22nd Apr, 2010 at 05:43:32am
What is the point of a 2.5 bar MAP when you are only running 0.6 bar?
22nd Apr, 2010 at 07:30:54am
Another thing if you are shopping around is be careful how they are described ie, the standard Cossie one is often referred to as a 2 bar sensor although it will only measure up to 1bar boost because it's working range is 0 bar(abs) ie, engine vacuum to 2 bar(abs) ie, 1 bar boost.
22nd Apr, 2010 at 08:48:18am
Oddly...I seem to have two beside me. One must be a std Cossie one.
22nd Apr, 2010 at 09:02:21am
cost
Other than it being a waste of money. See post above. Crystal Sound Audio said:
22nd Apr, 2010 at 09:10:42am
On 22nd Apr, 2010 Tom Fenton said:
What is the point of a 2.5 bar MAP when you are only running 0.6 bar? Or am I wasting my typing fingers, I think I am.................. You're not wasting you typing fingers, as previously mentioned - it's down to cost..... If I can get a 2.5 bar MAP sensor cheaper than one thats closer to my operational limits, surely it makes sense to plump for the cheaper option? Maybe it's just me being the stereotypical tight-arsed Scottish person that I am.... I'm also a student on a very, very tight budget. On 22nd Apr, 2010 Rod S said:
Another thing if you are shopping around is be careful how they are described ie, the standard Cossie one is often referred to as a 2 bar sensor although it will only measure up to 1bar boost because it's working range is 0 bar(abs) ie, engine vacuum to 2 bar(abs) ie, 1 bar boost. So make sure you know if they are being advertised as maximum boost or working range. Hope that makes sense..... Thanks for the heads up - I'll bear that in mind. Edited by MrOz on 22nd Apr, 2010. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
22nd Apr, 2010 at 09:46:56am
How much cheaper than £8.50 do you want, considering you were going to spend £50 at Emerald???????
22nd Apr, 2010 at 09:49:07am
How much cheaper than £8.50 do you want, considering you were going to spend £50 at Emerald??????? £8.50 would be great, but as it's an open auction - you never know what the end price will be. Of course I'm gonna bid on it, and if I get it for £8.50 that's top stuff - if I don't win then I'll need to look at alternatives. **Update** MAP sensor ended up going for £17.50. Edited by MrOz on 27th Apr, 2010. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
Braw.
